Build Advice PC Tool kit Recommendations?
Discussion in 'Hardware' started by Salty Wagyu, 4 Mar 2011.
  1. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    I'm looking to buy a PC toolkit for PC maintenance as the ones I have are inadequate - screwdrivers are not magnetic and it's made with small cheap plastic handles that have no grip whatsoever.
    I looked on newegg to get an idea and they have Rosewill RTK-045 which gets a lot of good reviews, but there are no Rosewill products whatsoever in the UK.
    What can you all recommend, and purchasable in the UK for a decent price? (under £30)
  2. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I tend only to use a screwdriver with my PC so any reasonable ratchet screwdriver and a bit kit should do you fine.
    If you want a bit more, this is basic but has pretty much everything I think you'd need: http://cpc.farnell.com/duratool/d00029/tool-kit-electronics-duratool/dp/TL10269
    As with most things, it's worth just stopping and thinking what you're actually needing. Once you've decided, have a look on ebay or similar and see what's on offer.
  3. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Thanks for your reply, will check out your link.
    I'm generally happy to get a complete set as I do not know what I need exactly when it comes to screwdriver sizes and so on.
    Another thing I forgot to mention about my current screwdrivers - they're probably so bad that they have in the past destroyed the tip of some screws, my first gen xbox for example when I was modding it. So I am looking for something with a bit more quality to prevent this.
  4. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Ratcheting screwdriver, thin metal screwdrivers and a screw extractor are all you really need tbh.
  5. adam_bagpuss
    24 Apr 2009
  6. Skellig
    Skellig What's a Dremel?
    2 Mar 2011
    Salty Wagyu likes this.
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    My tool kit:
    zip ties and canned airs too but they really aren't tools
  8. DMU_Matt
    DMU_Matt mmmm cheesy
    23 Oct 2009
  9. asteldian
    asteldian Minimodder
    13 Jan 2011
    I have something similar, though it has a soldering iron and torch etc.
    Though I'll be honest - the only things I use is the screwdriver and the little grippy thing that can pick up a dropped screw, and the torch
  10. wyx087
    15 Aug 2007
    single Phillips head screwdriver. nothing else is needed.
    oh, and compressed air for cleaning.
  11. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    wyx087 likes this.
  12. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Cheers everyone! :thumb:
    Might be going for the 43 piece from Maplins as Amazon don't seem to be selling the Belkin 36 piece at the moment
