Build Advice Pc upgrade time - what to buy?
Discussion in 'Hardware' started by nukeman8, 5 Oct 2014.
  1. nukeman8
    nukeman8 What's a Dremel?
    24 Jul 2008
    So recently brought Middle earth - shadow of mordor and was looking forward to playing it, of course i didnt check the min specs and lo and behold my gpu is woefully outdated.
    So while im in the mood to upgrade i thought i take a look at the rest of my pc.
    Currently running
    i7 920
    6gb ram
    geforce gtx 260
    i have sub £300 to spend, what would be recommendations for upgrades? Would it even be worth upgrading the i7?
    Currently i was thinking of getting a gtx 970 and upping to 12gb of ram which i can get for just over £300.
    Thoughts?
  2. johnim40
    johnim40 Minimodder
    23 Apr 2009
    Yes the 970 will definitely give a needed boost to the system
    The ram wont make much differnce for gaming but will help in normal day stuff
  3. davidbrown1988
    davidbrown1988 Minimodder
    8 Mar 2008
    Switching out that 260 for a 970 will make the most difference.
    For the average gamer the 970 is the smart choice at the moment. *Wishes hadn't bought 770*
    RAM wise a few of the more recent console ports have min specs at 6gb ram with recommended being 8gb.
    Dead Rising 3 being an example. That being said I haven't seen it use more than 2.5gb on max settings so these figures appear to be grossly inflated.
    If you only use your machine for gaming I'd wait to see if your RAM is limiting you in any games before dumping the extra money for 12gb. You'd be better served spending the money on an SSD (if you don't have one).
  4. GeorgeStorm
    16 Dec 2008
    +1 to the 970, great value card, the rest of the core of your system sounds pretty solid still.
    If you've got money left over and you want something to buy, then a SSD if you haven't got one already is definitely a good shout.
  5. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Looking at what you have I'd say just change the graphics card - the rest of it is fine. I was thinking of upgrading my own rig, but to be honest when it really doesn't and hasn't struggled with anything I've given it I shan't actually bother. Was looking to spend double what you were going to and I really don't think I'd see much of a difference.
  6. nukeman8
    24 Jul 2008
    Thanks all for the replies. I might still end up upping the ram as alot of games have 6gb+ as recommended and even thou no games seem to be using it I cant imagine it will be that long before they do.
    I recently got a ssd and im still amazed at boot time improvements heh.
  7. Rapp
    Rapp Minimodder
    3 Jan 2009
    Haha I done the exact same thing as you here I am thinking more towards replacing everything but know just getting a gtx 970 would do the trick.
