Build Advice PC won't boot after new GPU and PSU
Discussion in 'Hardware' started by David164v8, 16 Sep 2011.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Try without the GPU.
  2. David164v8
    David164v8 Minimodder
    29 Aug 2011
    Done that as well :( I'll try my old psu and see what happens there.
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    You connected any boot device to the power/motherboard as I can see the DVD Drive is disconnected in the pictures.
    Assume the HDD is connected properly?
  4. noizdaemon666
    15 Jun 2010
    Yeah try that, basic setup as well. Adding bits at a time.
    And Blogins, we're getting him to unattach stuff as it wasn't powering on properly originally (shutting down by itself if I remember correctly) :thumb::lol:
  5. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Oh BTW, you still need to see if it works with your new GPU and old PSU dude. That's the second step after ensuring it's all cabled up properly.
  6. David164v8
    29 Aug 2011
    My old psu only has 1 pci-e :(
  7. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    There should have been a 2 molex to PCI-e connector.
    I actually meant your new PSU with your old GPU though, that's what I meant, try that!
  8. noizdaemon666
    15 Jun 2010
    Oh and when running one stick of memory, use the 2nd slot from the cpu socket. Just incase :)
    Edit: when you took the gpu out, did you physically remove it form the slot or just unplug the power connectors?
  9. JTG06
    JTG06 What's a Dremel?
    23 Oct 2009
    Just be aware that Scansure will only cover goods you bought from Scan - i.e. if the motherboard is dead, you can't claim on your policy.
    Also, Scansure is designed to replace equipment you receive from Scan that is in perfect working order which you then go and break by installing, accidents etc (taking all reasonable care of course!).
    If it's dead on arrival, Scansure isn't needed - you just send it back to Scan as faulty and they'll refund/replace. I had to do this once and Scan were very fast in sending a replacement.
    You are also only covered for 28 days, so if you need to claim, make sure you do so before that time expires.
  10. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    I don't know if I'm being stupid and not had time to look at pics yet but should there not be a 8 pin plug as well as the 20+4?
  11. noizdaemon666
    15 Jun 2010
    *ahem* 2nd and 4th pictures *ahem*
    Move along, nothing to see here :D
    Edit: sorry, wasn't being rude, I didn't read the bit where you said you hadn't seen the pics yet :duh: :lol:
  12. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    Haha no worries, not at home and got rubbish phone signal so can't see them :)
  13. David164v8
    29 Aug 2011
    Hmm. I used my old psu and graphics card. Worked. I used my new power supply and old graphics card. Card spins, CPU fan spins, but the case fan doesn't and the computer shut down after a while. I try my PSU in my brothers PC with a 7800 GTX and it works fine. So I have no idea what could be wrong. The power supply doesn't work with either card in my PC but worked in my brothers.
    EDIT: I think one of my ram sticks fried as well. I removed it and thats when the computer actually started to boot.
  14. noizdaemon666
    15 Jun 2010
    What's your full spec?
  15. David164v8
    29 Aug 2011
    Dell 0M017G
    Intel Q8200
    Samsung HDD
    MSI Ati Radeon 6870/ 3450 (Old card)
    Toughpower XT 575W/ Liteon 350w (Old PSU)
  16. David164v8
    29 Aug 2011
    So, um. Should I return the power supply?
  17. David164v8
    29 Aug 2011
    Tested power supply with brother comp. Worked. Tried my 6870 in his. Worked. So somehow my computer is incompatabile with the power supply.
  18. Cei
    Cei pew pew pew
    22 Mar 2008
    Probably because it's a Dell? They like to change tiny things that only allow you to use Dell components.
  19. David164v8
    29 Aug 2011
    Ill get the link later, but there was a guy that had a Corsair hx620 and a 5850 in the exact same comp as mine. I don't think scan will refund me if I just say "Hurr durr it didn't work" Because it functions in other computers :(
  20. David164v8
    29 Aug 2011
    If my motherboard is the problem, I could buy a new one, right?
