Graphics PCB pics from a Fermi GTX480 @ CeBit
Discussion in 'Hardware' started by Xtrafresh, 2 Mar 2010.
  1. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    Hey, i spotted these, i thought the Bit-Tech crowd could be mildly interested.
    source
    Discuss.
  2. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    When are bit-tech and custom-pc allowed to review these ?
    You can bet their be pulling them apart.
  3. wyx087
    15 Aug 2007
    why are the PCIe and power connectors blacked out? it's painfully obvious what they'd be.
    those looks like digital regulators though, has nVidia finally given up on analogue regulators? will this mean no more whining noise?
  4. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    must be real... i cant see any wood screws :D
    sorry, couldnt resist.
  5. Jipa
    5 Feb 2004
    I think those have markings that could be tracked back to the manufacturer/source of the card -> NONO under NDA? Just my initial thoughts on that...
    Also liking how there's "just" 8+6 pin connectors, it isn't going to be too bad, now if only it idles at as nice a wattage as the new Atis do.
    And then to wait for my review sample :blush:
  6. Xtrafresh
    27 Dec 2007
    Jipa is correct. Tweakers.net got their paws on this sample for a few moments at CeBit, and in the article they state that they blacked out these markings themselves for exactly this reason.
    One thing of not that this article also states is that this sample concerns the A2 spin, while retail samples will be A3, so there still may be some differences.
  7. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    8+6pin power. Confirms that this series is worse than the 2900XT launch, as those only needed the 8 pin supply for overclocking.
    AFAIK the only other cards that need 8+6pin power are dual-GPU cards, but this is a single GPU card...
    Getting dangerously close to max power usage limits there nvidia ;)
  8. Elton
    23 Jan 2009
    This is going to be quite interesting, with that huge power req, one wonders how they'll tote the SLI card?
  9. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Few comments:
    That's a HUGE gpu die!
    I'm hoping that's a high end card - my 4850 (relatively high end last gen) only has a single 6pin power socket
    Why does the pcb have the airflow holes there if it's a single layer item? Seems to me the cooler doesn't match the card/there's a pcb missing?
    I remember when the 58xx/59xx series ati cards were launched everyone thought they were too long. This looks the same length?
  10. Jipa
    5 Feb 2004
    You should know some HD4890's come with 8 + 6 pin connectors ;) Dunno how commonly, but I've got one HIS HD4890 on the shelf that packs those connectors.
  11. Xtrafresh
    27 Dec 2007
    good point, mine also uses 8+6 :)
  12. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    The 4890's that had the 8+6 connectors weren't following the reference though... Most of the models with 8+6 usually had a power modification of some sort, such as Asus's TOP edition 4980.
    The GTX480 has an 8+6 pin stock, and is apparently pulling around 280 watts.
    Me thinks I'll still end up with an ATI card in the next month...
  13. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    What happend to the wood screws from the earlier version?
    Any idea on how long it is that must be closing in on a foot.
    My guess is that FERMi will give good performance but at a high cost.
  14. Synay
    Synay What's a Dremel?
    25 Oct 2009
    I agree, existence of 6 and 8-pin connectors hints that power usage will not be that much greater then GTX 285. Or if you want to count this way: 6-pin connector has output of maximum 75W and 8-pin connector can output maximum of 150W = max power draw can be 225W. If performace will be half of what they say, it's not that bad then, right? Unless of course you count that 225W plus PCI-E 2.0 output of maximum of 300W, then then numbers go crazy!
    In this case, my Corsair HX850 wouldn't be able to handle 2x GTX 480??? :jawdrop:
  15. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    Thats good, as if I was crazy enough ( and i'm already nuts ) to buy two of those I wouldn't have a problem. However, I would single-handedly start the next ice age if I turned the power on :0
  16. Pete J
    Pete J Employed scum
    28 Sep 2009
    Well, the problems with high temperatures can seem to be confirmed. The board seems to have those holes reserved for dual PCB cards and 4 big heat pipes.
  17. barndoor101
    25 Oct 2009
    dual PCB cards? when each chip consumes 280w? unless each PCB has its own power sockets it wouldnt be doable, and even then what would be the point over having 2 in sli? the heat will be a horrible engineering challenge alone.
  18. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    Look at the original GTX 295, each PCB had its own power conections, so I think it could be posible.
  19. Paradigm Shifter
    10 May 2006
    - You can't use the size of the IHS to gauge the size of the GPU die. :)
    - If the GTX480 is 8+6-pin, chances are the GTX470 will be 6+6-pin. I suppose we might be lucky and power requirements drop like a rock when it's not being pushed as hard, but that would advertise that the chip is running on the ragged edge in the 480 cards... :(
    - Probably some extra breathing holes for the centrifugal fan.
    4-pin black header for fan, 2-pin white header S/PDIF?
    I hope that fan isn't a GeForceFX/2900XT/dustbuster type... :(
  20. Pete J
    28 Sep 2009
    Sorry, didn't make my post clear. The holes in the PCB indicate that the card will have a cooler that is powerful enough to cool a dual PCB card like the 9800 GX2 or GTX 295.
    Would love to see the engineering heat solution to a GTX 495 though :eeek:
