News PCChips EZ-Watcher EZW-3060 Mini-PC at HardwareAnalysis
Discussion in 'Article Discussion' started by GreatOldOne, 10 Nov 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    PCChips - a name to send shivvers down your spine (if you've ever used one of their 'products'). Better known for their el-cheapo motherboards, HA have blagged one of theire SFF PC's to look at. Is it as [sarcasm] 'good' [/sarcasm] as there mobo's:
    Turn the Overclocking Dial, and the magic begins. As the dial is rotated, the EZW-3060 slowly increases the system bus clock, 1 MHz at a time. The digital display on the front changes to show the correct new clock speed, and for each 3% increase (or decrease), another bar on the LED display illuminates (or disappears). Extremists needn’t worry, though, as once you run out of bars, you can still keep on turning the dial, as high as your hardware will let you. A very neat concept, but will it hold water?
    Full review here
Tags: Add Tags
