Modding PCI card "modding"
Discussion in 'Modding' started by -dB-, 24 Jul 2009.
  1. -dB-
    -dB- Unrestricted
    21 Feb 2008
    Hi all, been a lurker here for a while and thought it was about time i said hello. I was bitten by the modding bug a long time ago, although my main victims were of the automotive variety. It has only been recently that i've turned my hand to computers. Im planning on modding my main workhorse (a CM690), but before i jump into the deep end and start dremeling my case to bits i thought i'd start by modding something smaller. PCI cards! here is a wireless network card i prepared earlier :hehe:
    Im also making a cover out of aluminium for my new sound card, ill post up some pics of that too if anyone is interested.
  2. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    That looks cool. But are you sure you wont create any permanant damage to your cards. I prefer to leave my stuff alone. Once a long time ago i spilt some glue onto my network card. After a couple of hours of use it overheated and frizzled out of existence. Make sure this doesnt happen with yours, leave enough room for air to get to the card. Also make sure that you dont touch the metal pins as they are very delicate. If any metal touches those pins you can disrupt data flows, ending in a very bad connection.
  3. -dB-
    -dB- Unrestricted
    21 Feb 2008
    The cover is made from acrylic and it is held on sparingly with insulative double sided foam tape. Ive had it off a few times, quite easy to remove. The aluminium mesh is glued to the acrylic but it doesnt come into contact with the card itself :)
    There is also about a 6mm air gap between the card and the cover so air can circulate.
  4. skybarge
    skybarge just chilling at work
    29 Feb 2008
    Very nice work mate :) I like it
    It shouldn't short out, since the Wifi cards only ever get touch hotness, never overly hot :)
  5. Mach
    Mach What's a Dremel?
    30 Jul 2008
    Very nice! I love the mesh.
  6. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Looks nice with that mesh!
  7. -dB-
    -dB- Unrestricted
    21 Feb 2008
    Thanks for the comments!
    Here is the cover i started making for my sound card:
    I have to remake it though because the lower screw head clashes with the pci bracket :wallbash:
