anybody have an official diagram inc. angles and shape of the pci/isa/agp expansion slot cover plate? i need the exact dimensions etc to have some brackets laser cut for a mod of mine. i could measure one with a ruler but its not precise
I find that a LOT of them vary in size, thickness, hole placement (if any) etc, best thing to do would get one out of the case and get some accurate measuring tool. Besides, I don't think they'd have to be so accurate that a ruler couldn't measure!!! ?
Bit off topic but I just wanted to say...Phat.... The chick in yoru avatar looks like a panther in the sack.
I should have an AutoCAD file somewhere... Now I'm at work, but I can sort it out this evening... Can you wait 'til tomorrow?!?! GeeK!
Hi loply, sorry for the delay.... Had to browse some CDs before I find this AutoCAD file of a PCI bracket. It's a 3D model with all bends and holes packed in a ZIP file.... Hope il helps! Linkie GeeK!
YUP! I have found some other drawings of misc things.... If you need something else don't hesitate to ask me! GeeK! P.S.: want to know more about your mod!
