Hardware PCI-Express 3.0 explained
Discussion in 'Article Discussion' started by Lizard, 27 Nov 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Backwards compatible, thank god.
  3. wyx087
    15 Aug 2007
    with different encoding method, presumably the controller chip will need to understand both for backwards compatibility. wouldn't that drive the cost of motherboard and graphics card up?
  4. Guest-16
    Guest-16 Guest
    Not really, it's just another fixed function in the silicon. The fact that it's faster already pushes up cost more because of the quality of raw materials needed to make the faster process reliable.
  5. Instagib
    Instagib Minimodder
    12 Mar 2010
    +1 That was the biggest pain in the arse about AGP -> PCI-E.
  6. adidan
    25 Mar 2009
    But the article says that it will be cheaper to make as it draws less power...
  7. battles_atlas
    battles_atlas What's a Dremel?
    6 Oct 2009
    Yeah I'm still pissed about how my old PC basically became obselete three months after I bought it
  8. NickCPC
    NickCPC Minimodder
    8 Apr 2009
    Nice article Rich, it's good to read some more technical stuff every once in a while.
  9. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Interesting - more bandwidth for the future console ports.
  10. Guest-16
    Guest-16 Guest
    No it says that 8GT/s is cheaper than 10GT/s, yet provides the same usable bandwidth. ;) It's a relative amount :)
  11. adidan
    25 Mar 2009
    Ah got ya. 8GT/s cheaper than 10GT/s but still more expensive than the 5GT/s of PCIe 2.0. It was early. :D
    One thing though, are graphics cards close to maxing out the usage of PCIe2.0? I am a relative noob in this respect.
  12. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I'm thankful they didn't increase power consumption again. 150W through the slot is plenty, and considering many enthusiasts own a power supply with at least a 6 pin connector, so we should be fine (Plus, I don't think people are going to be running 580 GTX cards with the current limiter off on 400W units)
  13. AndreiD
    AndreiD What's a Dremel?
    27 Nov 2010
    If I recall right, they didn't even max out PCIe1.1
  14. wyx087
    15 Aug 2007
    i don't think even gtx580 are hitting PCIe 2.0 limits.
    i shall take this upon myself and test :D if i place my sound card in 2nd 16x slot on my mobo, i'll force main GPU to run at 8x mode, which i can then test to see if performance is being limited. my guess is gtx580 won't even use full 8x PCIe 2.0 at the moment.
  15. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    You said it. Phew!
  16. Ljs
    Ljs Modder
    4 Sep 2009
    Indeed!
  17. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    I'm sure I've seen tests somewhere that showed the GTX 480 wasn't restricted by x8, so as we already have x16 waiting to become useful, who on earth is going to make use of this at any point before 2015?
  18. Mraedis
    Mraedis What's a Dremel?
    5 Sep 2009
    High performance SSD's? ^^
  19. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    So since graphics cards arent saturating 2.0 specs I would assume this is more aimed at highend Raid SSD PCI-E devices? at least for the time being....
  20. Yslen
    3 Mar 2010
    Actually there's an SSD still on the front page that could make use of it... I guess it will trickle down to us little guys eventually though.
Tags: Add Tags
