Other PCI-Express 4.0
Discussion in 'Hardware' started by silk186, 1 Jul 2018.
  1. silk186
    silk186 Derp
    1 Dec 2014
    PCIe 4.0 is on its way.
    The first products are AMD Vega 20 and a Samsung 8TB NVMe PCIe 4.0
    Will this have any benefit other than bandwidth?
    Are we getting motherboard support from Intel or AMD any time soon?
  2. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    In the enterprise space advertising stuff as PCI-e 4 compatible is nothing new, Mellanox for example has been doing so for quite a while already.
    There is no sign of Consumer CPUs / Mainboards supporting it in either 2018 or 2019.
    AMD plans to keep the current AM4 platform alive up to and including Zen3 in 2020 and that has even sparked rumours that AMD will skip PCI-e 4 on the consumer side completely and go straight from 3 to 5 around 2021 or so.
    When it comes to Intel, first they will shrink their existing consumer CPUs, so any significant new features can be ruled out for 2018 and 2019, maybe they'll add PCI-e 4 in 2020.
    On the server side of things it could potentially arrive sooner (in particular from Intel who have the resources to deviate more significantly between consumer and enterprise products), I wouldn't completely rule out a 14nm Xeon with PCI-e 4 in 2019.
  3. silk186
    silk186 Derp
    1 Dec 2014
    That's a pity, it would be nice to be able to have more bandwidth for devices. 2 lanes of PCIe 4.0 would be enough for current storage needs. I can imaging motherboards with 4x M.2 slots on the backside.
  4. RedFlames
    23 Apr 2009
    I'd rather see Oculink or whatever it's called come to the consumer space... replace the unwieldy slots with DP-like connectors and cables...
    Helps get away from ATX and makes SFF potentially more interesting by giving more freedom over what components you can put where...
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I don't know about Vega, but the NGSFF drive including PCIe 4.0 was just a typo, it is only PCIe 3.0 x4.
    There are so vanishingly few situations where you are actually limited by PCIe link bandwidth that I can't see there being any demand for it in the consumer space.
    Ditto, OCuLink even at PCIe 3.0 is exiting as it allows flexible placement of components.
  6. RedFlames
    23 Apr 2009
    I know i've seen server boards with it, but iirc it's limited to PCI-E 3.0 x8... but it still seems a neater solution than this:
  7. silk186
    silk186 Derp
    1 Dec 2014
    PCI-E 4.0 x8 would be enough for a GPU :grin:
  8. RedFlames
    23 Apr 2009
    3.0 x8 probably would be too tbh
  9. edzieba
    14 Jan 2009
