Graphics PCI Express x4 GFX Card?
Discussion in 'Hardware' started by Buzzons, 9 Feb 2012.
  1. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    My mobo has a PCI Express x4 (x8 Connector) spare currently and I need a low power useless graphics card to go in it to give me a 3rd output to power a 3rd 2407 dell screen - anyone know what i could drop into it to make this happen? (preferably nVidia)
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    You could put in a GT 520 or 430, PCI-E x4 slots have open backs so full size PCI-E cards will work, just with reduced speed or something.
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Would a geforce 210 or GeForce 8400 GS do? they're passive, and only about £20
  4. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    If it is just displaying basic documents, web pages etc then they should be fine, assuming drivers work. It won't work for gaming across three monitors unless you SLI with the same card.
  5. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    If the x4 slot doesn't have an open back, you can use a small pair of pliers to pry the end off or a small xacto knife to cut the end off.
  6. docodine
    10 Feb 2007
    Yeah, I was just suggesting some newer cards. Anything would work, really.
  7. Mac_Trekkie
    10 Sep 2011
    Though you really want to make sure you get a card from the same vendor as the one you already have, ATI doesn't play nice with others, and nVidia's not a big team player either. Yeah it's possible to get a multi-vendor setup to work, but it's really not worth it.
  8. docodine
    10 Feb 2007
    He said he wanted nVidia in the first post so I assume that's what he's already running.
  9. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Aye already running a semi decent 280GTX or something as the main card (it can do the stuff i need it to do) the other would really just to give me another DVI out. The motherboard is an S5000xvn - not sure what an openback slot would look like?
  10. docodine
    10 Feb 2007
    Well, the S5000xvn's PCI-E X4 slots aren't open back..
    If you think your hand is steady enough, you should try what Mac_Trekkie suggested and cut off the end of one of them. Otherwise, you could probably put a PCI video card in one of the PCI-X slots..
  11. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    oo they still make those? any suggestions?
  12. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Still make them? Nope. They're ass, worse than onboard Graphics in most cases, but you can definitely still get them.
  13. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    If you just need basic output, a GT210 pci-e X1 card should be just fine. They can do dxva 1080p video as well, but not really much for 3D like gaming.
    You can get PCI still, like the GS8400, but usually cost more than the GT210 and WAY crappier.
  14. docodine
    10 Feb 2007
    ^Good suggestion, forgot about PCI-E X1 cards. Get one of those!
  15. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  16. IvanIvanovich
    31 Aug 2008
    Yes. Zotac had a passive one, but not sure if it was on the 1x version or not.
  17. dunx
    dunx ITX is where it's at !
    1 Sep 2010
  18. Mac_Trekkie
    10 Sep 2011
  19. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    *sniff* my Amazon foo is failing to find one :(
  20. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    when it comes to cutting the back out, is it literally taking the tiny black edge from the rear of the slot away?
