Hi all I've searched and searched with no luck. I need a 3.3v 32-bit PCI riser for my mini-ITX motherboard. All the 32-bit risers I can find are for 5v slots. Am I right to believe that the contacts and notches for 5v and 3.3v are symmetrical? Could I buy a passive 5v riser and just plug it in backwards to give me a 3.3v riser that positions the card over the motherboard (component-side up)? That would be perfect. Thanks for any help. Apologies if I've overlooked a thread that answers this already. Simon
Goggle is your friend... This shows one, not in stock, but shows an HP part number... http://www.micomonline.co.uk/products.asp?partno=Q1247-60023&go ...it's a starting point. Google also turned up a lot of 64bit risers - I assume your PCI slot is a 32bit slot? Edit: found this (http://www.mini-itx.com/store/?c=8) - can't see the specs but they do have a few to choose from.
