News PCI-SIG announces 64GT/s PCI Express 6.0
Discussion in 'Article Discussion' started by bit-tech, 19 Jun 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Gareth Halfacree
    4 Dec 2007
    My bad: it's 'cos I'd originally started writing it in megabytes per second (which was a very-almost-doubling from 500MB/s to 985MB/s between PCIe 2.0 and 3.0) but switched to gigatransfers per second. Fixed now!
  3. adidan
    25 Mar 2009
    Don't pick on @Gareth Halfacree he's obviously just been doing his accounts for the taxman.
    MLyons and Gareth Halfacree like this.
  4. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    USB-IF could learn some lessons from this...
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    So something i don't get and I'm probably going to sound stupid for asking, but from what i gather implementing PCIe 4.0 on X570 has been more involved due to difficulties in maintaining signal integrity between the CPU and first PCIe slot, isn't that only going to get worse with PCIe 5.0/6.0?
    Or is that what the four-level pulse amplitude modulation, that i don't have the first clue about, intended to address.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    If what AsRock told GamersNexus is accurate, then yes, implementing PCIe 4 is a pain in the lower back (and also a major factor in the much higher price of X570 boards), so yep logic dicateates that implementing PCIe 5 & 6 will be bloody hard too.
    No clue though how much stuff like four-level pulse amplitude modulation can offset that difficulty.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    PCIe 4 doubled signal rate compared to PCIe 3.0 (implementation headaches), and PCIe 5.0 doubles signal rate again (more implementation headaches). PCIe 6.0 does not, it avoids signal rate increases by changing signal levelling. That's somewhat less of a headache as it does not change the traces, 'just' the PHY layers in the chips.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    Sounds like a good reason to just skip PCIe 5 then:thumb:
  9. edzieba
    14 Jan 2009
    Depends on who you are: if you're making a motherboard, implementing PCIe 5.0 means you're already ready for PCIe 6.0. If you're a chipmaker (at either end of the bus), implementing PCIe 6.0 means you have to deal with both the PCI2 5.0 signalling rate increase and the switch to 4-level PAM.
  10. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Is it just my imagination or are we going backwards now by adding faster links that draw more power and are harder to implement, yet almost nobody uses.
    I was about to mock the pointlessness of USB 3.2 10/20gbit when it occurred to me that M.2 NVMe drive prices have tanked and external enclosures are a thing. Dammit, there goes another $97 (58 quid) on Amazon; up to 900MB/s on a thumb(ish) drive should be fun though.
  11. ssj12
    ssj12 Minimodder
    12 Sep 2007
    Seems like when I upgrade my PC in 5 to 10 years the new tech will be great. (Running an i9-9900k currently)
Tags: Add Tags
