HTPC PCI TV card recommendations
Discussion in 'Hardware' started by Kronos, 6 Dec 2012.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    My TV in the living room is slowly but surely dying and to be quite honest I don't think I am going to replace it because it gets very little use.
    Instead I was thinking of installing a TV card in a PC I have kicking about.
    Specs:
    CASE: Fractal Core 1000.
    Mobo: MSI H61-P23(B3).
    HDD 1: 60GB Vertex 2 SSD.
    HDD 2: 250 GB.
    CPU: Intel G620.
    RAM: 8GB DDR CM3X2G1333C9.
    GPU: Radeon 4850.
    PSU: Jeantech JN120F-500AP.
    Optical Drive.
    I know nothing of TV cards but it would be useful if it came with a remote control and really do not want to spend very much as I could probably get a cheapo TV if a card was going to prove pricey.
  2. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
    I'm not sure if these are available in the UK or not, but the Ceton InfiniTV 4 products are the absolute best TV tuners you can get. They have a PCI Express version and a USB version. All you need is a cable card from your local cable provider, and you can tune in to 4 streams at once :)
  3. davefelcher
    davefelcher What's a Dremel?
    14 Aug 2009
    Hauppauge WinTV Nova T 500 (dual DVB-T tuners) is cheap and PCI.
    I've had one of these running 24/7 for maybe 6 years and it's still trucking.
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Can't connect to cable legally in the UK. Only the providers boxes are allowed to connect.
    Blackgold do some of the best ones. Not cheap but great cards
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Little more than I want to spend.
    Will have a look at this.
  7. davefelcher
    14 Aug 2009
  8. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    That PSU is totally pants.
    Sorry, couldn't resist. :hehe:
