News PCIe 2.0 to arrive by Christmas
Discussion in 'Article Discussion' started by Tim S, 22 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    10Gbit/sec Networking? Must. Have. Now.!
  3. Mister_Tad
    27 Dec 2002
  4. DougEdey
    5 Jul 2005
  5. identikit
    identikit Minimodder
    5 Jun 2004
    10Gbit/sec...now all we need is some crazy type of solid state HDD that plugs directly into the PCI-E 2.0 slot and matches the read/write of the network.
  6. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    And the switches,routers,cables to support it...
    Plus, it says it has 5GB/s bw.. not 10? or do you have to have two PCIe2 slots to get 10gbit?
  7. Mister_Tad
    27 Dec 2002
    You can get both switches and disk systems that have the speed to keep up with it, they just cost a (tiny) bit
    I think thats 5gb per lane
    so a 16c PCIe2.0 card would have a max bandiwdth of around 8GB/sec
    Even the current PCIe standard has more than enough bandwidth for current networking and RAID cards, though the most recent RAID cards are getting close with around 2GB/sec.
    How much bandwidth do top-end graphics cards pull through atm, it strikes me that they may be close.
  8. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    What worries me is the 150W slot+ 150W plug combination!
    Thats 300W for a GFX...even 600W in SLI. Great!
    Wasnt it Tim who talk about the way systems go ATM? Thats the wrong direction!
  9. completemadness
    completemadness What's a Dremel?
    11 May 2007
    lmao :p
    also, if it needs PCI-E2 why does the spec say
    "PCI Express x8"
    HM cos its a 1.25Gbps card, so it only needs a x8 PCI-E slot
    Why is bit saying it needs a PCI-E2 slot ?
    Also, dang that card costs more then a reasonable computer :eek:
  10. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Wasn't there a recent article having to do with large amounts of power consumption?
  11. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Hooray, all motherboards being useless :( I'd hope that this is backwards compatible (1 in 2, 2 in 1 etc) or i'll be mighty pissed.
  12. culley
    culley What's a Dremel?
    12 Jul 2006
    "also doubling the amount of power that can be drawn through the slot to 150W"
    Does this mean were gonna see more power hungry cards? If one slot needed 150w and you had SLi or Crossfire setup that would be 300w just for the graphics cards let alone everything else! :hehe:
  13. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Backwards compatible, yes, it's stated in the article (i.e. 1 in 2), for forwards compatible (2 in 1)? How often does that happen in computing?
    As for the 600W we're presumably going to see being needed for Crossfire and SLI set-ups, lol, me thinks people are going to need bigger power packs! Hopefully this increase in power will reach a plateu soon and it won't just keep eponentially increasing.
    As for the bandwidth speed though, mmm, very nice.
  14. completemadness
    11 May 2007
    SATA ? IDE ? AGP ? USB ? - the list goes on
Tags: Add Tags
