Graphics PCIe stuck at 8x
Discussion in 'Tech Support' started by Yaka, 23 Jan 2021.
    Yaka Modder
    26 Jun 2005
    so one of my kids has noticed fps drops playing halo, fortnite and rocket league on my pc. i have noticed doom eternal, warzone and death stranding dipping low fps than normal. and seems my gpu is now running at 8x instead of 16x
    my mobo is an asus Rog VI Extreme i have tried alot of settings and nothing seems to kick it back to 16x
  2. sandys
    sandys Multimodder
    26 Mar 2006
    what's the complete hardware spec? what do you have plugged in and what slots, can't imagine the drop for 16x to 8x to be much of an impact unless you are reliant on CPU RAM graphics buffer, I have a faulty 1080Ti that runs on 4x barely causes any issue bar lower overall framerates than when t was fully functional, no big dips.
  3. Yaka
    Yaka Modder
    26 Jun 2005
    its really noticeable in fps games. even tried the card in the other pc kids use and it runs at 16x fine on that
    my specs are are
    i9-7980XE
    rog extreme VI
    evga 2080ti top slot pcie 16x slot
    corsair 3200 64gb ram
    asus stx 2 + daughter board bottom 8x slot to reduce it picking up emi buzz from the gfx card
    samsung 960 pro1tb nvme
    samsung 2tb sata ssdx2
  4. Arboreal
    21 Jan 2011
    Is your board splitting the bandwidth between your main GPU slot and the lower 8x slot as you have a sound card fitted?
    Just a thought, I know some boards do this
    /2p
  5. wyx087
    15 Aug 2007
    Try re-sit your CPU?
    i9-7980XE is supposed to be 44 lanes. The mobo manual page 24 says 44 lane CPU should never need to split the top PCIe. Only instance where stop PCIe is split to 8x is with 28-lane CPU.
    How is your single NVMe drive installed? I see it's got an interesting DIMM.2 mount. Page 9 says M.2_2 on the DIMM.2 mount will make last PCIe slot run at 4x. Different issue but your sound card may not be running at 8x.
    (what a beast of motherboard, its manual had been an interesting read)
  6. sandys
    sandys Multimodder
    26 Mar 2006
    When you have had the freedom of a HEDT board you don't want to go back to normal lane limited boards.
    wyx087 likes this.
  7. Yaka
    Yaka Modder
    26 Jun 2005
    nvme is installed on the mobo it self, i remember on x99 mobos gpu had to be re-inserted a couple of times which i have tried to solve this issue which i have tried. i have re seated to the cpu and also checked if any of the pins are out of place in the socket its all good.
    its a wierd one, and bugging me gaming performance is not what it was like before
