Reviews PCSpecialist Myrmidon III PC Review
Discussion in 'Article Discussion' started by bit-tech, 2 Sep 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    not a fan
    super restrictive airflow case that is over 50% empty meets the magical ingredients to the hottest system ever + add in a "thin" single fan cooler for the lot and it equals a bunch of meh
  3. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    i'm dubious as to the cons including "lack of side window & RGB" - these are not cons in my book...
  4. GeorgeStorm
    16 Dec 2008
    Isn't there a smaller version of the case, very neat but so much wasted space!
  5. Paradigm Shifter
    10 May 2006
    I'll admit I've got no idea how hot the new Intel chips are supposed to run, but something doesn't seem quite right; I've got a box at work in a Define R7 and everything stays well within what I consider acceptable temperatures.
  6. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    I9s are stupid hot considering at this point in the game intel might as well be carving them by hand with chisel, but it is manageable
    And this doesn't seem to be doing that great
  7. Anfield
    Anfield Multimodder
    15 Jan 2010
    And the Meshify C was right there from the very same factory, would have even saved £10 or so.
    Osgeld likes this.
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    The temps are horrendous, to be honest. And calling something tidy simply because there is nothing in it?
    This looks like somebody put some decent finishing touches on it to make people go 'oooh, tidy' and instantly forget that tidy doesn't get you FPS or faster workloads. Temps on the other hand...
  9. Er-El
    Er-El Minimodder
    31 May 2008
    I'm no expert but how come the CPU fan is facing towards the intake case fan? Wouldn't it better if it faced the exhaust fan to keep the air flowing in one direction. Seems like they're working against each other, no?
  10. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    you could do that, its usually on the front, sucking air in from the front pushing it though the heat sink and blowing it out the back, if you want it on the back it would have to be in the same orientation just on the back, and hope it doesnt rub against the heat sink
    99.999% of the time the open blade side is intake and the side with the X and the motor spindle is the output
    so its going <F<<HS<F<<<F
  11. Anfield
    Anfield Multimodder
    15 Jan 2010
    Nah, it is 100% blowing air from the front through the heatsink and out the back.
  12. adidan
    25 Mar 2009
    100 degree peak CPU temperature?!? I think that cooler must have got dislodged in transport.
  13. Mobeer
    Mobeer What's a Dremel?
    19 Jul 2011
    Lack of side window and lack of RGB should be plus points
    perplekks45 likes this.
Tags: Add Tags
