Modding pearleasnt Liquid Cooling.
Discussion in 'Modding' started by mayhem, 15 Jul 2011.
  1. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    The one shown is Copper red. Yup no dyes used just a special mix of our pre-mixed liquid + suspension + pearleasnt. The pearleasnt used is coated to help keep it separated.
  2. mayhem
    12 Sep 2008
    Due to a conflict of interest on this forum i will no longer be posting info.
  3. mayhem
    12 Sep 2008
  4. mayhem
    12 Sep 2008
    Due to a conflict of interest on this forum i will no longer be posting info. mg]
    mvagusta likes this.
  5. Big Elf
    23 Apr 2009
    The purple is the best one yet, amazing.
  6. mayhem
    12 Sep 2008
  7. Big Elf
    23 Apr 2009
    What sort of flow rate do you need for the particles to be visible? Although I'm assuming it's low I just wondered how low.
    How well does it cope with micropins on a block?
  8. mayhem
    12 Sep 2008
  9. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    That would look ace in my ram block loop, as i dont need much flow for the ram.
    Infact i tend to use on 1 on d5 or even off is ok in cooler weather or non oc modes.
    would like to see your vid when you can.
    Is that white fluid available whilst your on?
  10. Big Elf
    23 Apr 2009
    That's interesting. At low loads my pump's doing a calculated 200lph with PWM at 20% (with no restriction), probably half that with the blocks in the loop so I reckon I could see the effect. I'll be interested if this becomes available.
  11. mayhem
    12 Sep 2008
    Im still working on getting the mix correct as im trying to avoid fall out with in respected flow rates.
    The pearl does separate when left alone how ever its picked up the instant you turn on the pump. Its just trying to get the fine balance between looks and this problem. It will take a little time to get right but ill get these in the end.
  12. thechoozen
    thechoozen Minimodder
    9 May 2006
    looks really amazing!!!:thumb:
  13. mayhem
    12 Sep 2008
  14. (FIH) The Don
    (FIH) The Don What's a Dremel?
    27 Jun 2010
    OMFG that looks soooo sick man :O
    when can i buy some :D want naaaaauuuuu
  15. mayhem
    12 Sep 2008
  16. mayhem
    12 Sep 2008
  17. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    They all look very cool Mayhem :clap: Nice to read they are handling abuse as well :rock:
    Have you made any reservoirs with lots of chambers/paths inside them? If not, then you must!!!111 I think they would be uber epic with any of these fluid mixes :jawdrop:
  18. mayhem
    12 Sep 2008
  19. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    That Galaxy one is brilliant!!!!
  20. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    has any testing been done yet, and when can we expect to see these on sale?
    I am interested in buying the galaxy one for my white and purple tj build
    Sent from my GT-I9100 using Tapatalk
