"PellenorFields" Lord of the Rings case upd 29/6/04
Discussion in 'Project Logs' started by borumas, 22 Sep 2003.
  1. borumas
    borumas What's a Dremel?
    22 Sep 2003
    Here's a bump, come on no one has any comments?
  2. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Cool idea with the casebadge mite have to try something similar :) Is the image clearer in real life?
  3. borumas
    22 Sep 2003
    Thanks, the image does look much clearer in real life, I just suck at taking picks without the flash on, LOL.
  4. Mixx
    Mixx What's a Dremel?
    19 Oct 2003
    iif you live down in ontario, theres a place called The Acrylic Depot that sells the exact same Green Plexi that Gnome uses. their site is
    www.acrylicdepot.com this place is down in the Greater Toronto Area (GTA)
    so if u live down here, that wud be the place ure looking for
  5. borumas
    22 Sep 2003
    Alright well I got a bit more done today, I got the panel glued , painted and test mounted. Here are some nice candy shots of it:
    After the glue set I painted it
    then I mounted it in place for test fitting:
    I'm gonna make another little stip of plexi to cover the rest of the drive cage as I had to move the plates back a bit more than I expected for the Molex pugs to clear, shouldn't be a big deal though. :D
  6. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Is this the drive cage? Are you just going to have the wires running down through the bottom?
  7. savethegaywhales
    savethegaywhales What's a Dremel?
    17 Feb 2004
    :jawdrop: Wow that looks fantastic. The etching is amazing. :thumb:
  8. borumas
    22 Sep 2003
    Yep, it covers the drive cage and the wires can run from behind the motherboard tray in through the other side so hopefully no wires will be visible- at least that is the look I'm going for.
    Man, put up allot of new pics, get over 500 views and only a handfull of replies? :waah:
    Hope to work more on it in the next week or so. :dremel:
  9. dream caster
    dream caster just lurking from out there
    1 Jan 2002
    Really coming out nicely!
    Very good work.
  10. borumas
    22 Sep 2003
    Thanks for the reply, I finally ordered the LCD and hope to get it in before this Friday:
    I like the blue, should match the theme nicely. :rock:
  11. MechWarrior
    MechWarrior What's a Dremel?
    13 Oct 2003
    Again ive been away too long. Insane insane work man! Very kickass!
  12. toand
    toand What's a Dremel?
    17 Feb 2004
    Excellent work, love those etchings :D
    Time to break the good ol´dremel :dremel:
  13. technomancer
    technomancer What's a Dremel?
    2 Apr 2004
    LEDs
    Absolutely beautiful etching work. Have you thought about using LEDs to light the plexi from the sides to make the etchings glow?
    Sorry to bump this since it hasn't been updated, but this is just awesome work :D
  14. borumas
    22 Sep 2003
    Hey not problem, thanks for the nice comments, and yes I do plan to light up some etches with LED's but not the ones that are painted over.
    I got in my LCD and wired it up today and tested it, I need to download and get the software working and mount the LCD in place. Here are some pics in daylight and at night with the test pattern:
    I had seen 2 different guides on how to wire this up and they were both different so I followed the one that had to potentiometers so I could adjust the contrast and brightness.
  15. technomancer
    2 Apr 2004
    Cool. I have to say seeing this has given me more faith in the design I'm working on. Planning on doing glowing hieroglyphics etched onto backlit plexi. :thumb:
    Looking good. I'm really looking forward to watching this progress.
  16. borumas
    22 Sep 2003
    Ok, got the mounting plate done and have it mounted, here are some pics (pardon the dust, it is always dusty in this house):
  17. technomancer
    2 Apr 2004
    Very sweet. You know, the more I see of this the more it screams for a completely custom case to highlight all the etched plexi. It almost seems a shame that it's in a tower case :D
  18. borumas
    22 Sep 2003
    LOL, yeah thanks, well I do have a totally custom case idea for my next project and if I can pull off what I have in my mind it will be pretty cool and it will have even more etchs that will be more like that last etch I did on the inside of the case (a total Celtic theme). :rock:
  19. technomancer
    2 Apr 2004
    Sounds sweet. Hopefully you can pull it off :D If this case is any indication the etching will look awesome :rock:
  20. dream caster
    1 Jan 2002
    It will be great but don't overdue; etchings need some flat area as a contrast to be seen.
