Pentium M,s Pentium 4 equivalent
Discussion in 'Hardware' started by P2D, 29 Sep 2005.
  1. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    Been looking around on the net for a few days and nothings what im after, All i want to know is,
    If i have a Pentium M 1.73Ghz CPU, What is its equal in Pentium 4 terms?
    e.g. PM 1.73Ghz = P4 2.4Ghz
    (And if you`ve got the info, Whats its equal in Celeron)
    Simple you`d think but everywhere i go starts explaing the architecture(sp?).. Yay.
    Mike.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Its hard to say, depends what your going to be doing with it...
    2.55ghz can match/compete with ~ 4.3 ghz P4/pressie, but only in certain things. ie, 3d/compression but things like encoding etc a much slower P4 will do the job...
  3. P2D
    26 Mar 2004
    I dont plan on doing anything special with it, its just i`d like to know what my Laptops CPU is equal to in p4 terms, So i`d guess from that info that 1.73Ghz PM = 3.5Ghz P4 Give or take a few?
  4. Highland3r
    25 Jul 2003
    In general, its PM speed * 1.8 = P4 speed so thats ~ 3.15
  5. ch424
    ch424 Design Warrior
    26 May 2004
    There're so many different configs for P4s and PMs that it's hard to say! When I got my Banias 1.7GHz pentium M, it was faster than a Socket 478 512kB 3.06GHz pentium 4. However, your Pentium M is a Dothan, so I'd guess it's comparable with something like a 3.2GHz 1MB Pentium 4 or perhaps faster than that?
    ch424
  6. Guest-16
    Guest-16 Guest
    If you only try to do 1 thing at once, around 3ish gig, if you want todo >1 thing, then... about half that :p
  7. cysus
    cysus What's a Dremel?
    14 Apr 2004
    Having delt with the Pentium M 1.73ghz (400fsb) and 1.8ghz (533fsb) CPUs as well as a 2.4C, 2.4B, 2.8C, 2.8E and 3.2C, I'd say the 1.73 about a 2.4C for the most past and as good as 2.8C in others.
  8. Guest-16
    Guest-16 Guest
    yea, like i said it can be twice as much or half as fast depending on whether you want it to do 1 thing or >1.
  9. P2D
    26 Mar 2004
    Mostly i`ll be doing 1 thing i guess, Since by the time ive moved the touch pad to the 2nd thing i`d do, the first would be finished, i`ll get the hang of it soon tho.lol
