Peripherals People with Logitech G15 that play WoW
Discussion in 'Hardware' started by Hoffs, 17 Jun 2009.
  1. Hoffs
    Hoffs Seek
    25 Apr 2009
    My Logitech G15 just arrived (Ordered it on ebuyer monday, free delivery and came today :D )
    Anyway, I load up the software and that's all installed
    But I was under the impression that when you play World of Warcraft, on the little screen it displays information unique to that game
    But when I load up WoW, all that displays is the default clock and other default logitech things
    Is there anything I need to install or do to make the screen display World of warcraft data?
    Hope you can help
    Edit: I think it's because I haven't downloaded the latest software from logitech. I tried this but because I'm using Windows 7 RC, it says my operating system isn't supported.. Looks like I'm back to square one.
  2. Jipa
    5 Feb 2004
    There's a list of supported games/programs in Wikipedia:
    http://en.wikipedia.org/wiki/Logitech_G15
    As it appears for what ever reason WoW isn't on the list, you must try to find a plugin from somewhere else. There are different forums and places to look for, but Google is your best bet. The plugins are actually called applets, which should help a bit in searching. Good luck! I lost hope of any real use for the screen already ages ago and now just use the screen for Foobar...
  3. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Just download the latest vista drivers, as effectively 7 = Vista, just a 0.1 bump in NET numbers (Vista is 6.0, and 7 is 6.1)
  4. Rkiver
    Rkiver Cybernetic Spine
    23 Apr 2009
    Wow works fine with a G15. You need to rescan for games, then select the game in the settings and have it force itself to the front. It works absolutely fine.
  5. Hoffs
    Hoffs Seek
    25 Apr 2009
    What do you mean force it to the front?
    And when I download the drivers, i download it fine, but when I go to install the vista ones, it says it doesn't support my operating system
    And what's foobar?
  6. rickysio
    6 Jun 2009
    Foobar is a media player that some people like. I still prefer WMP12, since it's not like the most desktops have so little RAM that they require Foobar, and most plug ins I use exist only for WMP.
  7. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    You need to make sure that you are using the correct drivers for the keyboard.
    Best way is to download the latest ones anyway.
    Follow this link.
    Select Vista as the operating system. If you are running Windows 7 64bit then in the 'select file' option select Multilingual 64-bit drivers. If you are using Windows 7 32bit then select Multilingual-32bit.
    Just click download (bottom of screen) and away you go. Once downloaded just install the driver. Works perfectly, I did this exact same thing last night.
    Once the driver installs, it will actually offer you the option to scan for installed games. Once it finds them it will set up profiles for those games (should they exist).
  8. Hoffs
    Hoffs Seek
    25 Apr 2009
    I tried that but just did it differently now
    Downloaded the drivers, opened the file in troobleshoot mode or compatiability mode or w/e it's called
    and it downloaded
    Now i have all my warcraft stats on my screen and i'm happy... Time to enjoy this keyboard a bit more :D
