Modding permanent paint for plastics?
Discussion in 'Modding' started by Yaka, 3 Feb 2018.
    Yaka Well-Known Member
    26 Jun 2005
    anyone know the best way to stain/etch/paint plastics?
  2. alfizzle
    alfizzle Well-Known Member
    3 Apr 2013
    Depending what plastic it is and the colour it is atm you could use plastic dye.
    I’ve used it lots of times to dye plastic parts on my RC stuff. :)
  3. Cheapskate
    13 May 2007
    For ABS like the stuff they use to dress cases, standard rattle can paint should have enough solvent to attach permanently.
    For something like plexiglas, you will need a self-etching primer.
  4. Yaka
    26 Jun 2005
    its plastic fairing and panniers (think these are abs) on my motorbike that i want painting i used plasticote on them a couple of years ago but some paint has begun to flake off
  5. dosmel
    dosmel New Member
    31 Jan 2018
    Try Krylon Fusion. This paint is specifically formulated for plastics.
