PeRs-pLeXeD ! -> Goes on display!
Discussion in 'Project Logs' started by Defyant Mods, 11 Sep 2005.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Time to fire it up , stand back and take a few shots! :)
    Time to switch some lights off
    With some UV lighting!!!
    Well i got it done in a weekend! altho i didn't rush the case...i still feel theres a few things i'd like to change.
    Cheers guys.
  2. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    :jawdrop: It really doesn't get much better than that...and it only took a weekend!
    Truly amazing achievement Defyant :rock:
  3. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Well. It's really quick and really nice. I ope the next projects would be at least so cool as this it. I still dislike full clear cases, but this one is awensome.
    In the pics, there isn't side panel or is?
  4. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Wow... Hats off to you my friend.
  5. ginx
    ginx What's a Dremel?
    1 Sep 2004
    youre crazy, i love it! very original idea too
  6. FaiNT`
    FaiNT` What's a Dremel?
    1 Sep 2005
    Wow thats real nice, never thought green plexy and a free weekend could result in so much!
  7. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    I want some of your free time.....
    Or maybe you can play with my children the next "free" weekend so I can work at my mod ideas!!!!
  8. Defyant Mods
    14 Sep 2004
    UPDATE!
    I wasn't happy with the front cdrom cover door thingy.... just looked like a foot to me...
    And i didn't bother to incorp an eject button.
    Had a bit of time to think about it @ work today and came up with this new door and idea for an eject button.
    some one had also mentioned the PCB for the buttons looks a bit outaplace thru the plex.
    A bit of black fixed this :)
    the design for the new door~! this time i went for a "sPLAT" rather than a gOoP!
    the idea this time is to attach the Green plex splat to a clear door panel which is already attached to the cdrom door.
    The Custom Eject button will be a "sliding cylinder" type construction and will consist of a shaped inner shaft that runs thru a hollow shaft with the button glued to the front.
    the whole assembly is then attached to the clear door panel.
    lost?
    the 2 main parts to the mod. an outer clear tube with a solid tube that runs inside.
    the inner tube is sightly larger then the inner diamater of the inner hole. this is a good thing because it will give me a rear stopper(foot) @ the back.
    Over to the bench press to take a few thou off the inner shaft.
    pretty crude! but it works
    A qick fine sand
  9. Defyant Mods
    14 Sep 2004
    You can see how the innner shaft now has a stopper @ the rear this will press up against the eject button on the cdrom.
    a sexy little green button is cut!! my god this was like micro surgery!!
    To take the sharpness off the button some heat is applied!
    it now looks more like alil green boiled lolly!! :)
    The clear front panel is marked and a hole is drilled for the outer cylinder.
    Good old plex glue will fuse bond this together forever!
    a qik test! all is good.
    Next is to glue on the button
  10. Defyant Mods
    14 Sep 2004
    The whole unit is attached back to the CDROM.
    the front splatt theme cover is glued on
    and finally! a finger test!! :) i love it when things just work!
    Well since i was modding along now!....... i thought that i would glue on the side splatt.
  11. Defyant Mods
    14 Sep 2004
    just little things! that were "erking" me... theres still a few things to do...i need to get a new side panel cut. orig was lost.
    and im keen to add a green LCD to the front as well.
    But i think you will agree its lookin better with each bit of etra work :)
  12. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    that is a really great looking mod! Have you ever considered taking your modding hobby and going retail with it, Cases by Defyant! I'd buy one!
  13. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    mini mod my arse! Thats a damm amasing mod, love the splat over the Mobo, when i saw it cut out it looked cool, then i realised it was a mobo cover :thumb:
  14. MrMan
    MrMan What's a Dremel?
    5 Jun 2005
    Extremely call defyant! no suprise there...... you really love that resivoir eh? :hehe:
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I don't know what to say...
    1 weekend, 1000 ideas, 1 case, 1 man >> 1 extraordinary piece of work.
    And the most impressive about this: It ain't the first time! You never run out of ideas do you?
    As always... :rock:
  16. LOTTARO
    LOTTARO What's a Dremel?
    1 Jul 2005
    WoooooooooooooooOO!
    VIUTIFUL!
  17. Bluefan
    Bluefan test 123
    25 Feb 2005
    Wow, this case is really unique
    (of course in the good way :thumb: :D )
  18. Dark_Bone_04
    Dark_Bone_04 What's a Dremel?
    8 Aug 2005
    :jawdrop: :jawdrop: nice work :thumb:
  19. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    awesome job as always :D
  20. htm_elle
    htm_elle What's a Dremel?
    8 Sep 2005
    I love what you consider a 'weekend' mod LOL
    A top notch product as usual :D
