Cooling Persivore and Highland3r's bench session
Discussion in 'Hardware' started by Highland3r, 27 Sep 2006.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    As the title suggests, myself and Persivore are finally able to get together for our first "proper" benching session. Persivore (for those that don't know) is a bit of an electronics whizz, and Xtremesystems resident vmod mod/guru. He's built himself a bit of a reputation as a vmod whizzkid and for those that have seen his work its certainly jusfiied.
    So, what's the plan? Well we've got 20 kilo's of Dry Ice on order, and some hardware which needs to be frozen ;)
    Temperature wise, we should see ~ -78 deg, should translate into some pretty cold CPU/GPU temps all being well :D
    We've got a set (well we will have if the GPU tube actually makes it back in time) of Chilly1 Dry Ice/LN2 tubes for the session. They're brazed tubes so don't quite have the performance of solid's but should be plenty for our needs.
    Also have a Prommy Mach1 here, with a Chilly head should it be required for GPU/CPU (or other) cooling.
    We've got a fair bit of hardware to play with, not all of it will be frozen but we'll do as much as we can over the weekend.
    So, what's lined up? Well...
    2 * LS28 Conroe E6600. (both chips have run to ~ 4ghz on watercooling)
    1 * Celly 326
    Various GFX cards (6800LE, GF 4's, possibly 7900GT + X1800XT if we get time)
    1* T2600 ES
    Asus P5B vanilla (awaiting mods)
    AOpen a-YDG
    and 4 gigs of Gskill HZ.
    Main aim's are probably going to be 2d benching, (pi's etc) and since neither of us have dabbled with Dry Ice before it'll be a learning experience for us both!
    Should be a good fun few days, will try and get some pics sorted once things take shape! Fingers crossed we don't loose any hardware either.
  2. atanum141
    22 Jul 2004
    Looks good, i shall be watching this closely!
    ninja edit: What about removing the heatspredders on the cpus? better contact = better OC's?
  3. DougEdey
    5 Jul 2005
    You aiming for 5GHZ?
  4. Highland3r
    25 Jul 2003
    Spreaders will probably remain attached for this session, maybe remove them once we've got a little more experience hehe
    5ghz would be nice, but doubt we'll make it that far with only Dry Ice. Hoping to see ~ 4.6ghz benchable from at least one of the CPU's though.
    <edit> 5ghz shouldn't be a problem with the Celly however ;) </edit>
  5. Highland3r
    25 Jul 2003
    Nice postman brought a huge box to the door thismorning, it was steaming nicely too!
    Results later :)
  6. alastor
    alastor Minimodder
    6 Sep 2004
    :brrr:
    Well I for one cannot wait :naughty:
  7. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    wow! cant wait for this one
  8. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Can you post a running log? :)
  9. Highland3r
    25 Jul 2003
    Sure. Just got back in from an outing, once we get setup will start things rolling. Later tonight/tomorrow morn most likely :)
  10. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Ohhh Looks interesting. Can't wait, GFs gone to see rellies so I have the whole weekend as a web hermit, it just got better. :D
  11. Highland3r
    25 Jul 2003
    So far....
    Run the Yonah, but no gains over Single Stage Phase. Gave up as Persivore needed the GFX card to test the P5B.
    Zero Condensation after an hour or so with the Yonah so that's promising.
    Persivores sorting the P5B mods now, hopefully have some Celeron/Conroe results soon :D
    Persivore nail varnishing.... the motherboard
    Yonah ready to go, paper on top is to stop shrapnel falling onto motherboard
  12. bazx
    bazx What's a Dremel?
    19 Aug 2005
    you got to lov the paper wings
    and h is that your nail varnish[​IMG]
  13. Highland3r
    25 Jul 2003
  14. atanum141
    22 Jul 2004
    WoWWeee!!!
    5Ghz on a Celly! isnt that nearly a 100% OC?
  15. Highland3r
    25 Jul 2003
    Yup, mobo limited so we couldn't make the extra :( 19mhz off 100%
    <ninja edit> 500 fsb on the Conroe - 4.5ghz so far </ninja edit>
    <ninja edit 2 > 512 fsb - 4.63ghz </ninja edit>
  16. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Good work so far. Need more pics, preferably with smoking dry ice, and frost :D
    (yes I know dry ice doesn't smoke, just couldn't think of the right word)
  17. Highland3r
    25 Jul 2003
    An arty one for you...
    And one of an ugly fu***r adding more Ice :p
  18. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    LN2 would be more interesting.
  19. Highland3r
    25 Jul 2003
    Yup it would indeed.
    Just sorting through results etc now will update in a few mins
  20. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    lurking...
