Cooling Pete's Watercooling log/how-to. UPDATE: UPGRADES!!!
Discussion in 'Hardware' started by Bloody_Pete, 10 Jan 2011.
  1. streetuk
    streetuk What's a Dremel?
    3 Jul 2009
    Oh well, I'll just buy a new case then that is better for water cooling and sell my Noctua NH-D14 that I bought last week. Why why why why why why why did I buy it (I don't know)
    ..............................:wallbash:
    :sigh:
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Well, I'm selling a load of fittings, it'll save you a tenner or so :) Check the marketplace :)
    streetuk likes this.
  3. feathers
    feathers Minimodder
    11 Apr 2009
    Fuzzy wuzzy pictures. Someone needs to stop using his Nokia as a camera.
  4. Bloody_Pete
    11 Aug 2008
    It's my GF's Cannon, just the lighting is rubbish and my hands gets really shakey :(
  5. Bloody_Pete
    11 Aug 2008
    Tubing has arrived!!!! At last!!!
  6. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    wooohoooo :D I look forward to seeing the finished article now :)
  7. Bloody_Pete
    11 Aug 2008
    Just closed up the rear pannel for the last time...
  8. Bloody_Pete
    11 Aug 2008
    Tubing now done :) Looks good :)
    And this is the wirong round the back, hopefully I wint be seeing this for a while, which is a shame really...
    Now to start filling it up :)
  9. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    What fans are those Pete
  10. Bloody_Pete
    11 Aug 2008
    Gentle Typhoon 1850's that I painted... its really easy :) They came out really well :)
  11. Bloody_Pete
    11 Aug 2008
    My filling system... :p
  12. Instagib
    Instagib Minimodder
    12 Mar 2010
    That looks awesome. Big fan of the red and black theme. :thumb:
  13. Bloody_Pete
    11 Aug 2008
    Thanks buddy :)
    I have one or 2 small leaks, no where critical, but its a pain none the less :(
    Are bitspower fittings prone to leaking? It's a 90 degree one thats dripping slightly...
  14. Kovoet
    26 Aug 2009
    Well damn good paint job there
  15. thetrashcanman
    18 Nov 2010
    Out of interest why didn't you put the 24 pin through the hole closest to the motherboard tray chum? :)
  16. Bloody_Pete
    11 Aug 2008
    I wanted to show it off :) And if you mean the one right next to the motherboard, it fouled the SATA ports (as I use basically all of mine) and my GPU...
  17. thetrashcanman
    18 Nov 2010
    Really? Hmmm Fair enough :) looks great though! is that XSPC tubing? I have some of there white stuff, i think its pretty nice :)
  18. Bloody_Pete
    11 Aug 2008
    Yeh, its really good, and very cheap... :)
  19. Big Elf
    23 Apr 2009
    Is there any sideways pressure on the leaking rotary, one of my dual rotaries leaks if there is. Bitspower apparently had a batch of leaking rotary fittings a while ago but new ones should be ok.
  20. Bloody_Pete
    11 Aug 2008
    Yeh, thats exactly it. It's annoying as I got them second hand, so they're probably the old ones...
