Cooling Pete's Watercooling log/how-to. UPDATE: UPGRADES!!!
Discussion in 'Hardware' started by Bloody_Pete, 10 Jan 2011.
  1. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I wanted something with lots of space, so everything isn't crammed in. And this way I never have to worry about 'if it'll fit' as everything will fit :) For the price its an amazing case, doubly so when they release the mounts to fit rads in the 5.25" bays...
    Ahah! I'll be reading that later :)
  2. dhughes
    dhughes What's a Dremel?
    1 Sep 2010
    haha, yes that looks very good at quick glance - I especially like the lighting tips and budget studio lighting alternatives.
  3. dhughes
    1 Sep 2010
    interesting.... I'll keep an eye on it, thanks for that.:thumb:
  4. Bloody_Pete
    11 Aug 2008
    Just a poke :)
  5. Zanib
    Zanib What's a Dremel?
    6 Jan 2011
    Looks cool
  6. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    friendly bump :)
  7. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    Had a question and thought of Bloody_Pete's thread! Helped me when planning my first loop and wonder if you can help again.
    My loop is running well, all things cool and dry but my Res is full of condensation. Is this normal?
    Appreciate any input.
  8. Bloody_Pete
    11 Aug 2008
    It can be, just means your water temp is a little warm. Shouldn't be anything to worry about :)
  9. Omoobhs
    15 Nov 2010
    Cheers for the reply. The GPU's feed directly into the Res so the water is probably at it's warmest at that point.
    May think about putting the Rad ahead of the Res in the loop as the condensation doesn't look at all pretty like.
    Component temps are good so I dont think I'm going to worry, but thanks for putting my mind at ease!
  10. Bloody_Pete
    11 Aug 2008
    To be honest, that probably wont make much difference, as that water temp in/out of a rad is only a couple of degrees difference is any kind of high flow system...
  11. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    question to the WC gurus here.
    Has anyone tried WC a CPU and GPU in Parallel configuration, instead of the typical inlet>outlet>inlet>outlet arangement.
    will both components get sufficient cooling fluid to keep them cool.
    (potentionally using an EK supreme HF and a EK GTX470 fullcover)
  12. Bloody_Pete
    11 Aug 2008
    The issue to the is whatever block has the least resistance will get the most flow and cooling, so I'd only think of doing this with high flow blocks...
    GeordieGoose likes this.
  13. GeordieGoose
    GeordieGoose What's a Dremel?
    18 Oct 2010
    Pete, TY for a great guide. + Rep
    Its wet :worried: my appetite to begin water cooling.
    I was hoping to do a small 240 radiator setup in my R2.
    Wanting to cut out the drive bays first and see if that makes much difference to my air temps.
    Currently getting ok temps but far to much noise.
    Running a noctua NH-U12P and 3 golfball fans + a gigabyte 460 makes for a noisy machine.
    :waah::waah::waah:
    Going to just cool the CPU at the moment as the 460 isn't a reference design and would rather wait to cool the GPU when I upgrade.
    Although adding a generic GPU block would mean I wouldn't have to buy one in the future.
    I know the R2 probably isn't the best case to do it in, but adding another £150+ for a new case would end up in me having to wait even longer to get started.
    more reason to get the dremel out :dremel::dremel::dremel:
  14. wodgah
    wodgah What's a Dremel?
    26 Jan 2012
    Really nice guide, thanks
  15. FifteeeCal
    FifteeeCal What's a Dremel?
    11 Jun 2011
    I might try watercooling soon, this guide was really helpful!
  16. Bloody_Pete
    11 Aug 2008
    No problem :)
    Its costly, but very rewarding :)
  17. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Hi pete, watched your video awesome for beginners like myself, just want some advice.
    I am unsure about which tubing size to go with, what would the most common size be, I dont want it too small but not 1/2 either. As its to my understanding that the tubing will dictate the radiator, pump and fittings, so need right option lol
  18. Bloody_Pete
    11 Aug 2008
    To be honest, this has been debated alot, tubing doesn't make that much difference (usless its very very thin). I've seen flow & pressure tests that show no real difference. The only thing to watch out for is that the wall is not too thin as this will make the tubing collapse more easily in turns :)
    And what video? I don't remember making one :p
  19. AoE
    4 Oct 2011
    Yes i think i'll go with 3/8 tubing. For the connections on a radiator, what size do I require if I am using 3/8 tubing? and can I use compression fittings to connect into the radiator?
    thanks again man
  20. Bloody_Pete
    11 Aug 2008
