Case Mod - In Progress Phanteks Enthoo Luxe Star Trek, 3-Way SLI ASUS Gaming PC, FINISHED 6/26/16
Discussion in 'Project Logs' started by mnpctech, 18 Aug 2015.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice project Bill. :)
    And I have since got into star trek, extremely late fan. :D
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Been a star wars fan since I was in diapers, force awakens has been a lifetime coming. :D
    Nice grills. :cooldude:
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    They are,I would consider an Empire one if it was hollowed out more.
  5. The Colonel
    The Colonel What's a Dremel?
    18 Jul 2014
  6. mnpctech
    21 Apr 2003
    yeah, "Heavy metal" is good description...haha and Top panel and bezel, finished for the Phanteks Luxe. Nest step is wet sanding the clearcoat on the side panels this Thursday.
  7. Icelander
    Icelander Minimodder
    3 Mar 2015
    airbrush looks great
  8. mnpctech
    21 Apr 2003
    Need to illuminate them next :thumb: We should have the side panels finished today.
  9. mnpctech
    21 Apr 2003
  10. Cheapskate
    13 May 2007
    You got me curious now. More airflow, a more dramatic taper to the center, or cut like the Rebel?
  11. mnpctech
    21 Apr 2003
    Bigger vents. btw, Did anyone else see The Martian this weekend? I'm calling it Ridley's Redemption for Prometheus :D
    Steps in painting Koolance Rp-452x2 Reservoir faceplate
    1. Medium grit sand paper to promote adhesion on face. (Not necessary to remove anodized surface)
    2. Clear off surfaces with Tack Cloth, and Tape Off inside portion of plate
    3. Apply SEM Self Etching White primer, allow cure for 30 minutes
    4. Apply 5 coats in 5 min intervals of Rustoleum brand Gloss White Enamel paint from Home Depot
    5. Allow Rustoelum Enamel paint to air dry cure for 24 hours before handling
    6. (Optional) Apply Gloss Clear coat finish to paint (next step this weekend)
    I use 3M 233+ auto body tape. Great adhesion, no glue residue
    I used a small touch-up brush on portions that didn't get fully covered with the tape.
    Tomorrow I'll clear coat it.
  12. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    amazing work as always.
  13. mnpctech
    21 Apr 2003
    Thanks for tuning in and commening! RGB lighting installed in top panel. Very EASY and effective mod for accenting the "16 BIT Spock" airbrushed mural by Brad
  14. mnpctech
    21 Apr 2003
    Had few minutes to work on this project over the weekend. Received Koolance 90 fittings, got the Koolance dual res installed. Also, for anyone interested in the Phanteks Enthoo Luxe tower, you can fit Darkside's 240/360 27.5mm slim radiators under the top cover. I'll try and remember to measure the total space under the cover when I return to the shop this week.
  15. mnpctech
    21 Apr 2003
    Thanks for waiting gang! Finished my Computex 2016 build obligations and back on this project, so yesterday I installed Bitspower's VG-980TIZEX VGA Block Acrylic (Clear) on the ZOTAC GTX980Ti AMP Extreme 6GB Video cards. I hope to start and finish the liquid loop layout this week.
  16. mnpctech
    21 Apr 2003
    While working on the PETG water loop, I recorded and uploaded a quick guide on cutting & bending PETG tubing for your PC Water Cooling
  17. mnpctech
    21 Apr 2003
    hey gang, I'm still alive, and the build is finally finished, I'll be taking and posting posting final pics this weekend
    yellowbomb likes this.
  18. mnpctech
    21 Apr 2003
    I just need to add the clear panel and it's ready to ship. I ordered a shipping crate from OriginPC, to save myself time. It includes foam and inner cardboard shell. Scale USS Enterprise was added to the photos for fun for mod zoo staffer, Graham
  19. kim
    kim hardware addict
    10 Jan 2016
    Fantastic...as usual...like all mods coming out from your magic workshop Mr Owen...thanks to share
  20. mnpctech
    21 Apr 2003
    Thank you kim! I'm excited to get back to my own build which will be excuse to finally my desk, too!
