Case Mod - In Progress Phantom 410 MOD - Project Log
Discussion in 'Project Logs' started by jompenleet, 1 Aug 2013.
  1. jompenleet
    jompenleet What's a Dremel?
    31 Jul 2013
    Welcome! This is a Project Log by jompenleet.
    This project is closing soon and iam starting a NEW PROJECT in a Phantom 820 case.
    The upcoming project will contain more reviews, pictures & tutorials.
    First i would like to thank all my sponsors
    http://nzxt.com
    http://kingston.com/en/ssd/hyperx/
    http://mnpctech.com
    I will be using the following from MNPCtech
    24" x 12" Acrylic Sheet (Smoked)
    http://www.mnpctech.com/acrylic_colored_sheets_casemod_windows1.html
    24" x 12" APPLY 3M Di-Noc CARBON FIBER FILM
    http://www.mnpctech.com/CarbonFiber_Gunmetal_Titanium.html
    MNPCTech long sleeved shirt in XL.
    http://www.mnpctech.com/Shirts1.html
    120mm grill Cable fan guard. This will only be used to locate where to drill holes for extra fans.
    http://www.mnpctech.com/Wire_Fan_Grill_Guard_Chrome.html
    U-channel molding about 8ft. Only to try if it improves the look of the side panel.
    http://www.mnpctech.com/moddersmesh.html
    24" x 12" Modders Mesh sheet round hole 60% airflow Might use alot of this
    4x Silver Anodized Case Thumbscrew's 6/32 thread
    http://www.mnpctech.com/thumbscrew.html
    2 x Cable Management Grommet 1-1/2" Inner diameter 2-3/8" Outter diameter
    http://www.mnpctech.com/PC_Cable_Rubber_Routing_Grommets.html
    http://sleeva.se
    Sleeva.se supplied me with all the sleeving, cable ties & shrink tubes you'll see in this project
    http://timwill.se
    Timwill's graphical designer helped me design all the logo's and stickers you'll see in this project
    This picture is one of the most recent
    Though i recommend you to check the last page in the thread for more pic's
    Here is the original state of the NZXT Phantom 410 case. (Just moved the components of my old OEM computer into the case)..
    Got a new Motherboard + processor + cpu cooler (Scythe Grand Kama Cross)
    After getting some new fans Xigmatek 1253 & a new fan to the cpu cooler Xigmatek XAF Series 140mm
    it looks like this.
    Interior before cable sleeving and cable management.
    :mad:Here i actually cut a whole in the side of the case to give it a bigger window.. And i forgot to take pictures sorry.
    Here's a link to the tutorial i followed to be able to do this!
    http://www.youtube.com/watch?v=WpZoE-zj0-k
    :thumb:Thank's alot to MNPCtech for the really informative tutorials on case mods!! :thumb:
    Interior after hardmod sidepanel + psu cover & fully sleeved cables.
    Tell me what u think! :)
    P.S Im still waiting for my stormtrooper sticker & white LED tubes for the case
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I've always liked your build, jompenleet, Looking forward to see what :thumb:
  3. jompenleet
    31 Jul 2013
    update
    Got sick of the orange LED fans so i decided to modify them abit..
    First i took apart the case and looked around for fans laying around..
    Found some!
    case without fans :-(
    Xigmatek F1253 and F1450 i think?
    Cleaning the fans for the paint to stick
    Safety first! (if u ignore this ur fans may not spin at all)
    Removing the LED's
    close up look..
    Fans on top of the case
    Scythe grand kama cross CPU cooler after painted the fan
    overall look
    Still waiting for stickers and Cold cathodes!
  4. jompenleet
    31 Jul 2013
    update
    Got me some watercooling now.
    And some new dust filters (the old ones sucked)
    Made a Hole in the PSU cover for the GPU Cables
    [IMG ALT=""]http://www.overclock.net/content/type/61/id/1463102/width/350/height/700[/IMG]
    Also painted the Chassi details in Glossy White
    Got two identical NZXT 140mm fans for the top (had too look symmetric)
    [IMG ALT=""]http://www.overclock.net/content/type/61/id/1463095/width/350/height/700[/IMG]
    Water cooling in place
    So what the case currently looks like.. Ill be getting some more parts next week.
    P.S Also installed some Revoltec Cold Cathodes....
    So i got some new stuff that my friend at timwill clothing drew for me..
    He also had some contacts to be able to make it in this frosty nice look :)
    Here we are applying a new sticker to the acrylic side
    finished!
    Also got me some custom made fan stickers, drawn by David @ Timwillclothing
    sticker on the modded 120mm xigmatek fan
    stickers on the modded 140mm NZXT fans
    [IMG ALT=""]http://www.overclock.net/content/type/61/id/1536947/width/350/height/700[/IMG]
    Voila!
    I do have some other things waiting to be done with this case (otherwise i wouldnt have this blue led still in there)..
    Check back soon and see what has happened!
  5. jompenleet
    31 Jul 2013
    update
    Ok so i got me some new stuff.. More paint(oil based high glossy hobby paint as usual), cable management items & some velcro tape.
    So. Take the case apart for starters.. Here iam removing the mesh from the trim
    Ok! Done for now. I also removed the heatsinks of my Corsair Vengeance DDR3 kit. (this mod is still in beta phase. I do not recommend you to do this yet, since i don't know how stable this mod is) since painting heatsinks could isolate the heat back into the ram chips. Though i will be using 2 extra thin layers of oil based paint for this test.
    Decided to go nuts with the spray can on all the black details of the case and ddr3 heatsinks to match the rest of the build.
    2 thin coat layers of paint. After that i left them outside under a roof to dry for 15hours. Since some of these stuff are going inside the case it is very important it is totally dry
    Im really happy with the cleanyness of the ram heatsinks! Hope they still work...
    Ok! using super glue to put the front panel cover back on.. Shouldn't break for the next 10 years.
    Will check back with you guys to tell you if this is the best thing on the market today..
    Applying double sided thermal tape on the memory (The same way as the stock thermal tape was applied)
    Ohhlalala!
    Ok! Now everything is back together. Time for some end result shots.
    Here is the first photo without side panel
    Upper Photo
    Front Photo
    [IMG ALT=""]http://www.overclock.net/content/type/61/id/1559970/width/500/height/1000[/IMG]
    Ram mod result Photo
    With side panel
    Will be checking back within the upcoming weeks with result of the ram mod. To see if i recommend it or not.
    But this Phantom 410 project is soon to be finished. I just have some re-sleeving to do, also building a new PSU cover
    Although i have already recieved a Phantom 820 case for my upcoming build.
    So stay alert and look for Jonas "jompenleet" Undestam.
    Have a good one
    So stay tuned!
  6. jompenleet
    31 Jul 2013
    update
    UPDATE!
    Ok so i got some new white sleeving from a company named Sleeva.se
    i don't know if they ship internationally. I do know they ship all over Sweden anyway..
    So here is what i ordered
    Shrinktube Small White
    Shrinktube Small*White
    Shrinktube SATA White
    Sleeve SATA*White
    Sleeve Small*White
    Cable-tie Brackets (10-pack)
    Lamptron Modding Tool Kit
    Some tools that will be used for sleeving
    A heat-gun is a must if you've got white shrinktubes. Because they will get abit darkened if using a lighter.
    Black shrinktubes don't matter though
    Lock ring pincer (inverted) to open up the shrink tubes abit.
    This was really useful
    Starting off with re-sleeving a 24pin Bitfenix Extender.*
    I did put an extra smaller shrinktube under the sleeving in each end for my white shrinktube to attach better onto the cord.
    This is some really high-quality sleeve, can't see through it at all..
    Finally finished with the extender.
    Took me a few hours to be honest :p
    This sleeve is abit thicker than the black stock sleeving on the extender so it'll look like this in the ends.
    I don't care though
    Sleeving is now complete, here is some results
    Graphics card 2x 8pin connections
    24pin mounted
    8pin mobo
    Scroll down for more pics
  7. jompenleet
    31 Jul 2013
    update
    So i got the idea of trying out some engraving.
    Since i had some extra acrylic laying around i thought i'd give it a shot.
    Don't blame me lol because i've never done anything like this before.
    Decided to put it here after i was done, now drilled some holes to be able to pop it there after i engraved the piece.
    These are the tools i used. A rotary tool, some Diamond Grinding things, a decal & acrylic.
    EDIT - *i found a flash light was also very useful for this
    Getting the logo in place
    Lets get started!
    So much fun!!
    Still going!
    Result after 30min's of work
    Results enlightened, if you look this close youll see 2 obvious mistakes. But this picture is very well zoomed. You wont see it if u look through the side panel of the case.
    Atleast not me :)
    __________________________________________________________________________________________________________
    End result, NO FLASH
    END RESULT WITH FLASH*
    END RESULT WITH FLASH & SIDEPANEL
    Will be doing some more small works on this, then im off to start with my Phantom 820 project wich will also be posted here on this forum.
    Look around for Jompenleet!
    Hope you liked it
