Scratch Build – In Progress Phase Changer RIG.
Discussion in 'Project Logs' started by rakesh_sharma23, 25 Aug 2011.
  1. rakesh_sharma23
    rakesh_sharma23 Minimodder
    2 Sep 2007
    So Here I am with first Test run of my Phase Changer unit.
    Yesterday evening I have started working on the Phase changer.. till 9 PM I am finished all fitting and ready to fill gas a test run..
    Since this is initial testing so I have not vacuumed the unit.. instead I have just flushed some gas through first and then just filled the R404a gas.. and started the unit.
    Initial temp was good but fine tuning the capillary placement in the evaporator.. I was able to reach
    -36C.. YES…COOL
    Turned off the unit let it heat up to the ambient temperature.. Now again started the unit to check time used to reach a temperature .. for ambient to -36c in just 3 minutes.. and power consumption is just 0.4 amp …
    (All analog and digital thermometer are calibrated in a Laboratory.)
    Not tested with 200W- 220v AC of thermal resistance .. At full load for more than ten minutes temperature remains to -32C.. …
    Mind I have not vacuumed the unit (It takes about 2 + hours).. after that I hope to reach -40C.. will do vacuum afterwards.
    Now assembling the PC together and insulating the evaporator.. it’s 1am so should have a sleep now..
    Will update more soon..
    Rakesh Sharma
  2. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Very nice build! Not many phase change mods in here! :)
    But are you sure the acrylic piece will hold up to the temperature changes in the evaporator? Just wondering, I don't want to see it shatter in there. :)
  3. rakesh_sharma23
    2 Sep 2007
    Thanks Sir,
    I have tested the Acrylic piece under -20c inside a chiller unit for two or more hours.. and nothing happened...
    Anyway if any thing happens .. i will try some thing else then... meanwhile want to proceed with this .
  4. Angel OD
    16 Sep 2007
    That sounds promising! :)
    I've never used acrylic under those temperatures, so I was just a bit worried! :)
  5. rakesh_sharma23
    2 Sep 2007
    Some More update...
    Insulated the mobo...(Still waiting for i7-2600K from RMA)..
    Have to purchase a GFX.. and a good one...
    Hope all are enjoying the build same as me.
    Rakesh Sharma
  6. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    why does building one of these from scratch just not seem safe to me?
  7. rakesh_sharma23
    2 Sep 2007
    Driving a Car is also not safe.. even walking on a road is also not safe... but we all do it...
    So.. just enjoy the life man...
    I enjoy modding..
  8. j0rd
    j0rd FLOSS folder
    13 May 2011
    no less safe than running the same hardware on a test bench but
  9. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    I've always been tempted to have a go at phase change but i've always been a bit scared!
    This mod doesnt make me feel any more confident!
    Great work, really impressed.
  10. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Sorry to de-rail the thread a bit, but the surface area of the CPU block is larger than the CPU, what happens between the block and where it overlaps? Do you put something there to stop the cold getting to the motherboard or just leave it?
    Thanks
  11. rakesh_sharma23
    2 Sep 2007
    Thermal Insulation sheet on back of Mobo and mobo Tray...
    Insultion clay filled around the cpu socket then a insulation steet layer above..
  12. Emil
    Emil What's a Dremel?
    7 Jan 2011
  13. rakesh_sharma23
    2 Sep 2007
    Got New GFX and i7-2600k ...
  14. Dragonphreak
    Dragonphreak Minimodder
    26 Oct 2005
    Your build is truly inspiring. Mod on!
  15. rakesh_sharma23
    2 Sep 2007
    More Updates
    RAM Cooler
    Adding Handles
    Some Cable Managament..
    Some OC..
    Evaporator at -36c, CPU socket backside at -23c..
    5.2Ghz. it was easy..
    Now have to refill the Phase changer for better temp..
    Will do more OC till Sunday..
    Rakesh Sharma
  16. Briaireous
    Briaireous What's a Dremel?
    29 Nov 2011
    Great mod :) cant wait to see how far you can overclock it! Keep it up
