Overclocking Phenom 2 955 overclocking issue
Discussion in 'Hardware' started by dead beat, 24 Nov 2009.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Basically, whenever I try to set the multiplier above 16x in the BIOS, this doesn't seem to be having any effect in Windows. When I load CPU-Z, it displays that the multiplier is still set at 16x and the core speed is 3200mhz (stock). However when I go back to the BIOS, it has appeared to have saved the changes, as it is showing the raised value for the multiplier.
    This means that the only way I can achieve any kind of overclock is by raising the bus speed. Seeing as this cpu should have an unlocked multiplier, I'm a bit stumped.
    Can anyone shed any light?
    Cheers.
  2. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    FSB is your best bet. Multiplier I have never used to OC. What you do want to ensure is your syncing, that is more vital then the clock speeds that you can get up to. A poor sync will actually make the system horribly unresponsive. I use a 3:2 ratio on my FSB/RAM. And I am able to pump the system very nicely and its very responsive. Just watch your Volts on CPU and your RAM as you may have to pump both a bit to achieve stability (if you pump your RAM up pretty high be sure you have proper cooling on them).
    Hope that helps. :)
  3. dead beat
    15 Feb 2009
    Thanks for the response, and I can see what you're saying. But seeing as it is a black edition processor, I would still really like to get to the bottom of why I'm unable to increase the multiplier.
