CPU Phenom II list of compatible mobo's
Discussion in 'Hardware' started by vincentnone, 7 Feb 2009.
  1. vincentnone
    vincentnone enthusiast or fanboy?
    19 Nov 2007
    this is amd's recommended mobo's for the phenom 2's
    can anyone add any mobo's that you know for a fact work with the phenom 2's?
    MSI K9A2 Platinum (MS-7376) 1
    780a SLITM MSI K9N2 Diamond (MS-7375) 1.1
    Asus M3A78-T 1.01G
    MSI DKA790GX Platinum (MS-7550) 1.0
    Gigabyte GA-MA790GP-DS4H 0.2
    ECS A790GXM-A (RS780DM-A) 1.0
    Asus M3A79-T Deluxe 1.01G
    ECS A780GM-A Ultra (RS780M-A2)
    Gigabyte GA-MA78GM-S2HP 2.0
    Gigabyte GA-MA78GM-DS2H 2.0
    MSI KA780GM (MS-7552) 1.0
    previous page
    http://products.amd.com/en-us/RecommendedMBResult.aspx?f1=AMD+Phenom%E2%84%A2+II+X4&f2=940&f3=C2&f4=&f5=&f6=&f7=&f8=125+W
    and can anyone confirm whether or not this specific mobo works with phenom 2's yet
    DFI LP UT 790FX-M2R
  2. Elton
    23 Jan 2009
    I think the Majority of the 790FX boards should work, if not then a BIOS update should fix it..
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I'm 90% sure the DFI 790FX and FXB boards would worw.
  4. vincentnone
    19 Nov 2007
    thanks for the reply
    anyone know when the first am3 specific boards are going to be out?
    so far all I've seen are those am3 mini atx boards
    and a few full atx boards saying they're am3 ready
    when's the good stuff coming
    how many of you have bought the phenom 2's already?
  5. frontline
    frontline Punish Your Machine
    24 Jun 2007
    I have a Phenom II 940 running on a DFI Lanparty Jr 790GX M2RS. Micro ATX board but very sexy, with dual PCIE slots for crossfire :)
  6. vincentnone
    19 Nov 2007
    did you need a bios update for that?
  7. frontline
    24 Jun 2007
    Yes, there have been 2 bios updates released by DFI, the first one was a bit flaky and didn't name the CPU properly, the latest bios works fine though. Have had it stable at 3.6ghz on air-cooling with a small voltage increase, but am running it at 3.3ghz on the default voltage at present.
