I have found an LCD its a philips model that uses the HD44780 controller. I think its a 2x16 model but im not sure. I need to find a data sheet for it but havent had any luck yet. Firstly, where is a good place to look for a data sheet? Secondly, It only has 14 connectors so i assume there is no backlight, would it be ok to use cat5 cable (x2 of course) and how long should i limit the length of the cable to? TIA
http://www.eio.com/public/lcd/ ... post it there and someone will prob help you out. Ps. Bomberman rocks!
Have you any idea of the model number for the LCD, whats printer on the back of the circuit board ? How long a lead do you need 2m is normally not a problem
OK sorry for the delay in the reply, i have not had the LCD to hand, I took some photos but they didnt come out very well at all lol. Anyway, Ill take a look at that link thanks AtomicWarMonkey, And yes bomberman rocks (well it did once) Prankster - There are no markings on the screen or PCB that would sugest what kind of screen it is, It just looks like its a 2*16 because of the size of it. vdub - There are no markings on the back except the markings on the controller chip (4a3 - HD44780A00 - Japan) and the Philips logo thats etched into the PCB. On the front there are 2 numbers printed on the edge of the PCB. They are, LPM3575-1 and QJK413H.
