Case Mod - In Progress *** PHINIX AURORA *** - 12/10/14 - Grand Finale !!! It is done...
Discussion in 'Project Logs' started by phinix, 24 Jul 2012.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Ha!:) I can imagine!
    I was shocked when my daughter sent me a text from her mum's phone for a first time. That was a real hit:) My first thought was like - aha.. so there it is.. I won't even know when I'll start getting texts saying "How are you dad? Everything ok? Do you need anything?"...
    They grow so fast... too fast...
  2. phinix
    28 Apr 2006
    Hi guys, I have a small update for you today.
    This is work I done last and previous weekend, so you can see how little time I have for my modding during the week;)
    First dvd measured up and mounted - I had to measure depth of the dvd drive - how deep can it go to touch acrylic front panel.
    I drilled two holes in white shelf and screwed it down.
    Also mounted whole drive cage/reservoir acrylic spine and mounted this white beautiful reservoir I got from EK.
    Then I tried out front panels bits, not finsihed, but wante to see how it will look so far...
    That was two weeks ago, now what happened yesterday...
    I had to align and mount this sweet little Scythe fan controller.
    So first tried it out with just alu front panel bit...
    I had to mod this controller metal cage, cause it was getting in a the way of front acrylic panel and needed to install it right behind top alu bit...
    That is better, filed down sides and got rid of front bits...
    Then I cut out some small L shape alu bit so I could easily screw it down to the acrylic front panel middle bit and to the controllers cage.
    You can see here, it will be mounted below the controller cage...
    3mm thick acrylic panel will be enough to hold it down. I had to drill and tap those holes:D
    Now I'm waiting for new screws to be delivered for this - I ordered very short 4mm M4 screws for this to be mounted.
    In the meantime, have a quick look at front panel - top bit covering dvd will be glued to the acrylic bit behind, so it's only lying there.
    Name bit, middle grill and bottom triangle are screwed down. Acrylic bits aren't finished yet, some edges need to be filed down and sanded, will do that later.
    So it's just a wee mockup for you:)
    Imagine all black bits being white and white light glowing behind those blue acrylic bits... there! This is how it's going to look like when I finish it:D
  3. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Nice front and nice work all together.
    I'm looking forward and am excited about the other interior work you've planned for this build :)
  4. phinix
    28 Apr 2006
    Thanks.
    Everything will look a lot better when it gets powder coated, white satin:thumb:
  5. douglas alves
    douglas alves Minimodder
    3 Mar 2014
    Muito bom o seu trabalho. tudo combinando, estou acompanhado..
  6. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    That front looks sooo good
    Not totally convinced about the white reservoir yet though..
  7. phinix
    28 Apr 2006
    Thanks.
    Res needs to be white, you will see it when all gets powder coated satin white.
    I was busy last month (jury duty and my mum's visit), but I'm planning powder coating the whole case in next 2 weeks. Almost all aluminium work is done now, next step will be coating it and then putting it all together and wiring it up. Then water cooling loop will be next.
    Should finish it before summer vacation:worried:
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Ohhhh, can't wait to see how that finish turns out!
  9. phinix
    28 Apr 2006
    Update time.
    As I mentioned before, all metal work is done.
    I started to dismantle the case and clean it up with high grade sand paper before I send it to powder coat place.
    Let's see what has happened in last month.
    Here is how it looked last time.
    Top panels are ready, only need to screw them down.
    Holes drilled in first piece.
    Then acrylic piece measured and drilled.
    Second piece was straight forward, same steps here...
    ...and all screwed down. Job done:)
    Top panel ready to go, still need a hole for fillport....
    Now here... slight change in mounting of front panel. I really didn't like the way it was done in first place - M3 thin screws going through the front alu, acrylic, then front panel.. too many layers and hard to find a hole in almost 30mm thick front panel.
    So I added M4 threaded inserts to those acrylic mounting blocks and decided that front panel will be screwed from the sides! Brilliant! :D
    I tried out dvd to see how it aligns.. looks perfect to me...
    ...and front covering bit.. will be glued at the end.
    Now the controller - here is how it's gonna be mounted.
    It sticks out too much, so I trimmed it a bit to make sure it will fit in the radiator cage.
    Now these little beauties...
    Seriously, those feet are so sweet I'm not gonna powder coat them. I will keep them clear, cause the shine so nicely:)
    Yes... I like feet... :eeek:
    Drilled and mounted.
    I tell you, fast mounting cutting wheels are bless....
    I had to make some small gaps for dvd cables on the top of that plate.
    I also had to make these - small acrylic blocks with threaded inserts for mounting top panel.
    Case frame drilled and ready for mounting...
    That is it for now. Next week it will be all packed and sent to Tom in ChilledPC for powder coating goodness...
    Now, I still don't know where I'm going to mount power switch !!!:waah:
    Any ideas ???? :worried:
  10. mnpctech
    21 Apr 2003
    maybe on back of the chassis, Mike?
    and coincidental timing on your update, we just finished making more of the Diamond Knurl PC Case Feet yesterday!
  11. hanssx2
    hanssx2 Minimodder
    1 May 2014
    subd.
    just love you acrylic work :)
  12. phinix
    28 Apr 2006
    You're right Bill! Power button is going at the back:thumb:
    I gotta say, those case feet are AWESOME!
    Cheers:thumb: I'm not the expert in acrylic, but have to say I like to work with this material.
  13. mnpctech
    21 Apr 2003
    Cool, Looking forward to seeing next update! :rock:
  14. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    I really like this build but the front panel looks awesome!
  15. phinix
    28 Apr 2006
    While I'm waiting for the case to be powder coated, I wanted to show you what I have received from Monsoon Cooling company. There is no need to introduce this brand - all watercooling enthusiasts know it very well. Their innovative compression fittings rule on all forums.
    They kindly supported my Aurora project with these items:
    • 3 kits of white compression fittings
    • 2 white 45 degree adapters
    • 6 white 90 degree adapters
    Here's a full box:)
    Each set has its own key tool and two sets of gromets
    ..all boxes emptied:)
    water cooling p*rn:)
    All will complete water cooling loop in my Aurora. They will look awesome with blue tubing.
    Now we just need to wait for case to come back from coating.
    Tom from Chilled PC is also cutting left side panel window. Of course design is matching front panel.
  16. phinix
    28 Apr 2006
    Last weekend Tom from ChilledPC emailed me that case is done, nicely powder coated and ready to be sent. I'm going on holidays now for 2 weeks so Tom will send the case to me upon my return. That means I will show the results at the end of this month. I can only imagine how this case is going to look like coated all in white:)
    Next step will be putting the case together with all the custom parts, soldering all the lights for the case (mostly front panel), then mounting hardware in it, building the water cooling loop and that's it! I wanted to finish it in July, but it looks like it's going to be August now;)
  17. mnpctech
    21 Apr 2003
    lookin forward to seeing the new powdercoat finish! :thumb:
  18. phinix
    28 Apr 2006
    Me too Bill! :)
    I'm back from holidays and case should be with me this week.:thumb:
  19. phinix
    28 Apr 2006
    And finally I got all the stuff back - look how many pieces it is!
    Original front panel
    Fan grill/cover ring looking sweet in white:thumb:
    Custom front bits that will cover original panel
    Here's a side panel with cut out window and mobo wall...
    All pieces again
    ..and front pieces including top dvd slot:D
    Now it is time to put it all together. Tons of screws, nuts, rivets waiting to take part of this sweet little case:)
    Will post the progress soon, I'm really busy all the time, going on a wedding next week.
    I will be working evenings building it for final stage. Stay close!
  20. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
    put it together!
