Case Mod - In Progress *** PHINIX AURORA *** - 12/10/14 - Grand Finale !!! It is done...
Discussion in 'Project Logs' started by phinix, 24 Jul 2012.
  1. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    If it IS acrylic... I suggest NOT to use alcohol. If it's Polycarbonate on the other hand, you should be fine. :)
    Awesome start to yet another amazing mod i presume! :thumb:
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Yah... if there are ANY tensions inside acrylics and you add alcohol to it, bad things will happen. At least with extruded acrylics. Not sure the same applies to cast acrylics, but I guess so?
  3. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
  4. Angel OD
    16 Sep 2007
    Just wanted to do an example for you guys, so you could see what happens with acrylic and alcohol. :)
    I am 100% sure that this is cast and not extruded, since cast is the only thing that works when using it to draw fibers from. :)
    Drilled a couple of nice holes in it and filled them with alcohol. (99%)
    2 seconds later:
    There's your sign! :) Just a friendly warning!
  5. Owndapwn
    Owndapwn What's a Dremel?
    13 Jul 2012
    O_O
    That acrylic thing....
    Does that affect the structure of the acrylic?
    Like....... Say I'm considering modding my Tempest 410 to have a clear window in it, but want something for the case lights to catch on....
    And I flame treat the edges and splash rubbing alcohol on it (It's like $4 for a half gallon at Sam's Club. Not the best alcohol solution, but dirt cheap and not that bad) and it spider cracks along the edges, would it still be able to support the dual 120mm fans I would mount to the acrylic, and would it remain solid enough?
    'Cause if you WANT that design, that'd be a very simple way to do it for a very nice result, but does it ruin the acrylic for more than just aesthetics?
  6. sixfootsideburns
    6 Feb 2009
    Without a doubt it will compromise the structural integrity of the acrylic. Whether or not that matters with your application is up for debate. My guess is it won't matter much, but I imagine it will make it more delicate. Acrylic can withstand some abuse, but with that kind of crazing I would assume "playing nice" would be a good idea.
  7. Cheapskate
    13 May 2007
    @Owndapwn - You could do 2 layers, one crazed and one glued on for strength... or 2 crazed on one side and glued facing each other. -Did it with the 'Toad.
    :lol: Forgot the original question. Naphtha on toilet paper. It should be OK on plexi. I just cleaned a spot today in fact.
  8. Owndapwn
    13 Jul 2012
    Dx If anyone has an extra sheet of scuffed up and unusable sheet, I would be VERY greatful if someone could test how much abuse it can take.
    I may be able to do a second sheet, but I'm not sure how much acrylic is.
    Hell, these would be $64 alone. That's already as much as my case cost.
  9. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Cheers guys - I know what happns when use alcohol on acrylic, that is exactly why I didn't use it.
    I investigated it a lot when was making Phinix Cube and found out that alcohol isn't good for cleaning acrylic. Not even cast, when you caut out some shape from cast acrylic, alcohol can still ruin it by getting in all micro-scratches.
    No worries, I will not use alcohol for cleaning it:)
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Warm soapy water, give it a soaking washing it by hand & if needed a rub down with a good microfibre cloth without adding scratches.
    Next time keep the protective film on the acrylic & stick the templates on the film to cut the bother out. :)
    That tinted rod is awesome not seen tinted rod before now & cheers for the link phinix, :) some interesting bits there & the SSD rack idea is nice. :D
    5 stars :dremel:
  11. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    haha, Well, I'm very excited to see how you'll be implementing our case mod products. Mnpctech is honored that you chose Us! :thumb:
  12. FifteeeCal
    FifteeeCal What's a Dremel?
    11 Jun 2011
    That SSD mounting system is insane! This build is looking gooooood.
  13. phinix
    28 Apr 2006
    Thanks Waynio - that is exactly the method I used to clean it up. I used washing liquid and it worked fine, still needed a bit of rubbing, but final result was great.
    I will keep film next time I use those templates:thumb:
    Thanks Bill! Your products are top quality, I'm happy I can use them in my new project:rock:
    Thanks, glad to see you like it:thumb:
  14. phinix
    28 Apr 2006
    Guys, sorry for a bit long absence. My mum visited us for a month so I made a vacation from most of my activities:)
    She also bought me this and from the moment I installed it, it takes pretty much all my free time now:D
    But now I'm back!:clap:
    Of course the problem is that during a week I come back from work around 7pm when it's already dark, so cannot work outside. Only moment I can do some work are weekends.
    Today I spent few hours on finishing SSD cage/brackets.
    So here's a minor update.
    I can only work outside now, no more cutting aluminium or acrylic at home:D
    I'm saving some money for a new shed, which will be long and spacy. I will put all my tools there and will be able to do all my modding (read: make mess all over the shed:D)
    Right now, this work bench is all I have:waah:
    I was filing the edges of all SSD pads. Lot of work especially those small short edges inside.
    Couple of hours and it was all done.
    I also cut off two pieces of this blue acrylic rod, which will be a spine for the the whole drives/lcd/reservoir structure.
    I took it all home and used 400 grid sand paper to polish all edges under water.
    After 20 minutes it was ready to try out:)
    I'm pushing those rods with my hand so those shelves won't drop down. Those holes are a bit bigger then 20mm rod dimiter - they will be drilled through and screwed in with M3 bolts. I will use small brass inserts to mount them, same as I used in Cube.
    Here's a try out in the case. All fits in perfectly, those rods will be mounted in special aluminum frames at the bottom and top of the case. Simple alu pieces with 20mm holes screwed in the the case base and fabricates top frame. I'll show that later when will be closer to mounting it all in.
    As you may noticed, at the beginning I wanted to do 4 shelves, but nowadays, when SSD prices dropped and bigger drives are much cheaper I don't think I will need 4 drives in the PC. I will go for 128GB, 256GB SSD and one HDD for storage. Enough I think...
    Of course I kept forth piece in case I change my mind later on. Structure will be easy to dismantle in case I would like to throw in one more drive. Flexibility is also important in the project:)
    Last photo - here are M3 brass inserts I mentioned before. These are perfect for quick and easy installation of acrylic parts. I will use a lot of them in this project.
    OK, this is it, small progress, but wanted to share it with you guys, I hope you don't mind.
    Next week will be cutting aluminum sheet to fabricate power cage!
    See you next time!
  15. krussellusaf
    krussellusaf What's a Dremel?
    28 Jun 2012
    This is going to turn out amazing. I can't wait to see more.
  16. Sarakon
    Sarakon The German
    11 Feb 2011
    Already looking awesome :) Looking forward to the next update.
  17. mnpctech
    21 Apr 2003
    Excellent! More, please :D
  18. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nice work I'm glad to see this project progressing and I am looking forward to more updates!
  19. mnpctech
    21 Apr 2003
    Any new updates? excited to see what you do next, phinix :D
  20. mnpctech
    21 Apr 2003
    Haven't heard any updates, hope everything is OK?
