Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. aurora
    aurora JAVA GURU !!!
    10 Mar 2008
    Nevermind, it worked! :)
  2. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Great thanks for all the wishes and positive feedbacks!
    Another little update: look what today came in:
    It is so small...
    My brand new slimline slot-in dvd for sweet little cube:)
    This is how I'm going to mount it: red acrylic strips will be screwed to the top panel with nice shiny bolts.. Here's a small series of sketches...
  3. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Happy Birfday! ^_^
  4. phinix
    28 Apr 2006
    THANK YOU! :)
  5. phinix
    28 Apr 2006
    Taped new dvd with chrome film and cut and polished those holding strips. It's hard to show real colour of plexi, especially when light is pretty bad. Even that dvd doesn't look like it really looks;)
    ...and with flash it even looks kinda orange...:(
  6. jhanlon303
    7 Sep 2006
    What happened to this!!!!!!!!!!!!!!!!!!!
    Modding on your birthday will probably earn you a ticket somewhere.
    Nice update but we can wait one day. Go enjoy:clap::clap::clap:
    John
  7. phinix
    28 Apr 2006
    I know:) I can barely write on keybaord, but made that dvd few hours ago and wanted to show it:)
    Now going back to drinking....:clap:
    P.S. man, I love my keyboard, its so soft....mmm...:D
  8. phinix
    28 Apr 2006
    Small update - sketches only .. for now:) I will show some moves next week...
    After deciding to move dvd to the bottom...
    here is how I'm gonna light up few things on lower level - dvd and PSU will have red acrylic plate below them - iluminated with leds from the inside so their edges will glow... I know.. sweet...:)
    and where is how I had to modify drive cage to mount dvd at the bottom.... small feet... happy feet...;)
    That's it...
  9. phinix
    28 Apr 2006
    Another update - this time - front panel sketches...
    I've been working on my front panel lately.. I'm pretty bored now at work so played with Sketchup a bit...
    Like I mentioned before - center of the panel is that chromed ring with 6 reqtangular red leds, same as Crysis logo which I love....:)
    Center of that ring will be covered with black mesh and behind that there will be leds attached to rec acrylic lightning it from the edges... I hope it will look as pretty as it sounds :)
    Everything started from measurements..
    Option 1 - top buttons in different order..
    Option 2 - buttons changed
    ...and the final, cube with front panel... You can see here what I'm going to do in the middle - it is that chrome ring with LEDs aka Crysis:)
  10. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    I like that very much! I can't wait to see it on the cube. :thumb:
  11. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Nice :)
    I have nearly the same DVDRW here.
  12. hotdog
    hotdog What's a Dremel?
    5 Feb 2007
    Just curious...can you add the fans to the front panel to see how it would look?
  13. phinix
    28 Apr 2006
    where? rhere is only place on top level...
  14. phinix
    28 Apr 2006
    I'm planning to add 3 switches to the front..
    How does it look like? ok?
    They gonna switch on/off led loops - under cube, inside psu and dvd led-loops and front ring leds...
    Or should I just put them on the back of the case to prevent ruining front look?
  15. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    it looks way cooler with the switches, great job on this by the way:D
  16. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    Great work,you are really pushing the limits with the dimensions of the case.I think it looks ok with the switches.
    Regards.
  17. phinix
    28 Apr 2006
    Great:) Thank you guys!:)
    I was affraid that those switches won't match with the whole slick idea...
    Those 3 holes above swithces are knobs from that controller I bought - I put photos a few pages before. I'm going to reallign those knobs and get rid of those 2xUSB. Another I/O panel I bought - Solverstone one, I'm going to mount on the right panel - it has 4xUSB (that is why I do not need them on the front), mic in and audio out, 1xFireWire.
  18. phinix
    28 Apr 2006
    UPDATE TIME !!!!!!!!!!!!!!!!!!!!!!!!!!!
    UPDATE TIME !!! (...finally...!!!)
    I cut from red plexi small feet, showed that before. Drilled holes for bolts and tried them on.
    Then I sanded them and polished edges...
    After radiator feet I came back to drive cage. Measured evertything and cut two equal panels with my tristy dremel:)
    These are those aluminium pipes that will hold both panels together and hdds will hang on them using velcro tapes... I cut them again, using dremel... my cutting wheel got smaller a bit after that process:)
    I drilled holes for pipes in panels...
    Then had to drill those pipes and thread them - this is PAIN IN THE ASS!!! I had to do it in my hands, have no clamps or anything like that...:(
    Like I mentioned before chroming is very expensive. SO decided to cover those pipes with chrome effect vinyl tape...
    How I did that??? Cut small strips of vinyl and roll those pipes through !! EASY !!!:D
    They look amazing !!!
    Then I cut small feet for drive cage - to stand it up above dvd...
    ...and now...
    Finished DRIVE CAGE....
    Here you go...
    THAT'S IT FOR NOW !!!
  19. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Man, Phinix...that is really bad-ass! I love the HDD cage.
  20. jhanlon303
    7 Sep 2006
    That chrome tape stuff is something I would never have thought of!:clap: Excellent cage.
    John
