Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. ZeroHerO
    ZeroHerO What's a Dremel?
    17 Dec 2002
    Looking good so far :)
    ZeroHerO
  2. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    You do realise you can plane perspex, yes?
    Excellent edge and helps with straightening cuts. Very quick and easy.
  3. xsolonx
    xsolonx What's a Dremel?
    16 Nov 2005
    hahaha great technique for the inserts, back when i was at a machine shop that was always my least favorite thing to do, even with the press we had specifically for that.
  4. Nix
    Nix What's a Dremel?
    22 Nov 2005
    Glad to see youre also on here with your work log Phinix :)
    Great work so far
  5. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Yes.... UPDATE.. I don't believe it either..;)
    After a while I made some improvements but didn't want to show you bits, wanted to show you that I actually did sth in the last few weeks. So I drilled holes in panels and bought more screws. It was really hard, because holes must be drilled very precisely. 1mm on any side would make fixing panel impossible... I think you guys know what I mean... So I had to measure inserts in square rods and draw them on panels.. with my shaking hands it was really annoying :)
    But first - drive cage.. like I mentioned before I used aluminium profiles to build cage. Used small screws to do that. Of course it looks pretty ugly, but it will be covered with chrome film, which I also already bought. Here's cage:
    I'm running out of screws so it is not folded properly yet... Both sides have only one screw:)
    I have also bought rest of parts for watercooling - T line thing, fillport and of course BLOODY RED coolant :cheese:
    AAAGGRRRR:)
    I have to show you cube itself now..:)
    There you go:)
    Here you can see I used small red acrylic bits as .. hmm.. washers.. why? because bolts are long enough to fix main panel AND red one on top of it as a decoration.. you know.. so had to use those for now, uuntil I prepare my front panels..
    Like I said, precision is important.. here you can see how the panels are folded together..
    This is bottom "foot" for radiator:
    ...and radiator itself..
    Here's drive cage nside this sweet cube:)
    ...and with mobo tray:) (still unfinished)
    I hope you like it... Still a lot to be done.. but I passed another semester on my CISCO course, so now will work more on this baby:)
    STAY TUNED !!!
  6. Jewno
    Jewno industrial designer
    4 Feb 2004
    updated today or last year?
    btw, nice project. am looking forward to this!
  7. Asulc
    Asulc Minimodder
    18 Jul 2007
    Great planning going into this mod. It has the possibility to be a great one!
    *Subscribed*
  8. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Woo! updates!
    my only concern is space, but with the planning you put into it, i dont see it as an issue.
  9. phinix
    28 Apr 2006
    Thanks guys!
    I do not worry about space - as you saw I planned this for almost a year.. Considered different setups, but the last one is fine to me. It may look like pretty tight, but every part has its own place.
    It is hard to see it now, but when I take off those white tapes from panels it will be soo beautiful.. you'll see... That acrylic looks so amazing...
  10. cheezeit
    cheezeit What's a Dremel?
    29 Aug 2007
    I found this mod about a week ago, and like it! I had been planning to build a 300x 300 x 300 cube with aluminum tubes and a rad on top for quite a while, but I could not find an arrangement which took most advantage of small space, cooling, and a nice view at the same time. Instead, I am now planning a small tower.
    However, your use of panels instead of a main chassis really allows you to fit more into the cube! You put a lot of planning and precision into this build, I'll be looking forward to updates!:thumb:
  11. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    hey dude where abouts did you get the black vandal resistant (bulgin) switch from, looks mean!
  12. phinix
    28 Apr 2006
    KustomPCs
  13. phinix
    28 Apr 2006
    Ordered some new plexi today - red transparent, 3mm. Huge, 100x60cm, I'll be able to cut 6 panels, 30x30cm. I'll cut 4 for front back and both side panels. Use one for mobo tray - changed my mind again.. I dont want to use that light edges.. they just too bright, too pink-red. I need red-red plexi:)
  14. phinix
    28 Apr 2006
    In the meanwhile.. package just came in !!! WOOHOO!!! :D
    My new E8400...
    and those panels - AKASA fan controller and Silverstone FP32.
    Sorry for the photo quality, my camera is dead, so used cell phone.
    It’s not hard to imagine what I’m gonna do with those panels. AKASA will be ripped out from its cover and I’m gonna pull those knobs to my controller in the right upper corner of my cube. The main pcb will be hidden in a silver box.. hopefully.. at the bottom level. Same the Silverstone I/O panel - will be ripped out and I will place all sockets on the right side of my cube - left upper corner of right panel.. MAYBE wil put it somewhere on front, but not sure.. right side would be more comfortable… we’ll see…
    Now I’m waiting for my red acrylic plexi that should be here today… the one I was looking for.. no glowing edges, no pink.. just real red…
  15. Guest-23315
    Guest-23315 Guest
    Where did you get the little M3 acrylic joint bit-things?
  16. phinix
    28 Apr 2006
  17. phinix
    28 Apr 2006
    Anyway...
    This control panel is nice, really nicely built, shiny black paint, small and tasty:)
    Look how small is the main pcb - it will be SOOO easy to take cover off and just install it on my front panel.. I dont even have to build a cover for it...
    Silverstone I/O panel isn't such a beauty like akasa... but still nice and perfect for my cube.
    Look at the back of that panel - all stuff is nicely packed in that white cover! That means I can use it without any box, just attach it to right panel of my cube and that would be it! So easy.. that's great, I'm happy:D
    A lot of cables though... :eyebrow:
  18. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Very good start! I use the same I/O panel in my mod. BTW where did you get the feet from? The look great.
  19. phinix
    28 Apr 2006
    Feet, if you already noticed - are the same as Sugo has! I bought it at KustomPCs.
  20. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Subscribed... 'nuff sed!
