Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Hahaha:D Don't worry:) You will see it before you die:)
    Very good question! No after I'm almost at the end of the project I've learnt a lot and know what afre the bad sides of building the cube from acrylic.
    - size of the hole - its for M4 screws
    - side panels - black ones? hats 3mm, most popular coloured acrylic sheet you can get. Clear ones, the main panels are 5mm, but if I was going to build again, I would use thicker ones... 5mm is minimum for full stuff inside + water cooling.
    - that cubic rods are 20mm, 10mm I think could be not enough for all screws, unless you gonna switch it with aluminium ones, then 10mm would be fine
    - 400mm sound perfect. Mine is 300mm but its very tight in there. If you gonna water cool it, then 400mm would be great. Mine 300mm is pretty tight and I think its minimum. I had second project in mind with alu structure and 350mm sides.....
    I hope that helps.
  2. Degenerate83
    Degenerate83 What's a Dremel?
    4 Nov 2008
    gratz on motm nomination!!!!
  3. phinix
    28 Apr 2006
    WOW!!! Sweet! Thanks! I haven't expect that! :)
    So guys, if you like my cube... please vote! :D
    In this case, for this partucular occasion looks like I cannot wait and keep it under cover - I will have to show you the cube with all the panels now:) I need to finish front one first and in next couple of days you guys gonna see full view of the cube:) Yes.. FINALLY !!! :clap:
  4. jhanlon303
    7 Sep 2006
    MOTM is back! Congrats on the nomination.
    john
  5. DocTrooper
    DocTrooper Modding Intern ???
    14 Feb 2009
    Phinix, Congrats on nominated for Feb 2009 mod .... You deserve it :clap:
    My planned cube would have at least 6 x 80mm intake with 3 x 80mm exhaust fan to cool it temporary until I can figure out the water reservior display portion.
    Thanks once again for your input, Phinix !
  6. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    Looks so good!
    I love the plexy letters, very clean work!
  7. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    Voted!
    And now, let us see your baby :)
  8. phinix
    28 Apr 2006
    Thanks Mino:)
    I worked a bit today to file all edges in front panel. Tomorrow will finish it with dremel and high grade paper + polishing compound. I would like to drill all holes in it and install front ring as well, at least without leds. Then I'm gonna do some photo-shoot for this darling:)
    So hopefully tomorrow will finish front panel, glue those small triangles together, which you guys haven't seen yet (those ones which blink when the Crysis intro starts and EA logo show up) and glue them to the ring. I have 12 triangles, 6mm high each, pretty smal, will glue them in pairs to cover led holes, it should look awsome when I light it up:) But I will take care of lights next week.
    Now need to figer out how to make those photos tomorrow to show whole cube nicely..:)
  9. Loom
    Loom What's a Dremel?
    10 Aug 2008
    I'll vote for you if you give me all your stuff that's for sale :naughty:
  10. jhanlon303
    7 Sep 2006
    One small hint from a MOTM winner.
    It doesn't have to be finished to win! :rock:
    Keep up the excellent quality and cut no corners just for the contest/voting.
    I won with H2O-C7 and the support of BT and it's not finished yet. DO NOT HURRY. This is a cool project and as such demands the time you spend.
    john
  11. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Very-true..
    I won MOTM and had only just-begun.. This stuff takes time...
    I like this project.....
    I added a (5) star rating as well as my vote for MOTM..
    Do it right, take your time.. I have my eye on you..
    PS: don't hang your hopes on winning and getting "free stuff"..
    Despite what bit-tech says...
    I won September 2008
    As of 2/27/09 I have received : nothing.. 0.. zip.. no-replay..
    Bit-tech's MOTM is bragging-rites and nothing more..
    I don't have a problem with that. I have a problem being deceived into thinking MOTM is more than what it is..
    Shame on bit-tech..
    MS
  12. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    I agree!
    Even I won the MOTM and my project was at 1/3 of the build stage, and after 3 months or so I've received the goods...
    But the prize is not the stuff , is the honour to be the winner...
    BTW, I was really proud to be in the pool, a friend gave a call to me at 5.00 am to tell me that I was the winner..
    Anyway, don't hurry, take your time and do a good job, the prize is nothing versus the quality of the mod,,,
  13. b00mb1ast3r
    b00mb1ast3r Testdrive unlimited LoVeR
    25 Dec 2008
    congratulations for the MOTM, i really loving this mod, I have to say that i love the CRYSIS Ring its really beautiful!
  14. spenc259
    spenc259 in the build stage!!!
    23 Oct 2008
    congrats on the nomination man... you deserve it based on the quality of the work!
  15. Montspy
    Montspy What's a Dremel?
    28 Feb 2009
    WoW ! Your mod is one of the most beautiful plexi mod that I've seen !
    Good work man !
    And good luck !
    Montspy.
  16. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    congratulations for the nomination :clap: The text on the case is nice and the got an good place keep-it up man :thumb: you got my vote :D
  17. Guest-16
    Guest-16 Guest
    Get in touch with us with your address. You're not the first and it seems the guy we left it to organising and collecting address etc, basically, didn't. We're just learning of this in 2009 and we are NOT happy in editorial :miffed: :miffed::miffed:
    Dennis has a dedicated department for doing this now - in future it'll be down to them but at least from 2009 we're doing it all in house now to make sure it gets done.
  18. The boy 4rm oz
    10 Apr 2008
    Congratz on your MOTM nomination mate. Hope to see more work from you soon.
  19. phinix
    28 Apr 2006
    Guys, thank you all for kind words. I'm glad you like my work. Don't worry I won't skip any of my plans just to try finish it before MOTM ends up. I will continue all my work like I did before.. slowly:D However I should be able to show you the cube with all panels on this week. I work today and tomorrow till 19:00 so won't do anything till Tuesday or Wednesday, but then I will have huge update with REALLY nice photos:) So stay tuned! :)
  20. Combatus
    16 Feb 2009
    Yep, well done Phinix, I was very impressed with the cube! Don't rush it though, as jhanlon303 says MOTM is about mods in progress. Once it's done we can maybe talk about doing a feature on it :thumb:
    Incidentally, the sunbream case you nearly got - I got one a while back and threw some water-cooling gear inside! clicky
    Antony
