Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. Jeddy
    Jeddy What's a Dremel?
    12 May 2008
    Try lowering the voltage through them with a resistor?
    Try spreading like 9v through the 6 of them, it should reduce their brightness.
  2. stuartwood89
    20 Aug 2008
    +1 for naked.
  3. JesterQ
    JesterQ What's a Dremel?
    15 Jul 2004
    this is looking an impressive mod .. ! will follow with interest :eek:)
  4. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Hey, pistol_pete - you are an expert as being gas turbine engineer, tell me please - if I make this gap bigger - 1,5cm would that be a huge difference? Would it help a lot? I hope it would - I'm planning to recreate rear panel and move PSU 1cm on the right from the fans. I'm not sure how gas is spreading and getting sucked in front of the fan (I would have to smoke a cigarette and blow in to see how its going through the fan:D) but I hope 15-17mm would be a lot better than 5mm, correct?
  5. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    I preffer the naked release, but I know that it's not like the logo you want....
    Maybe try to sand the triangles a little bit, and if the light is too much you can sand even the leds without undervolting :)
  6. phinix
    28 Apr 2006
    Yeah, I was thinkning about sanding the leds, cause I already soldered them with resistors and put heatshrinks on those so it would be a pain to change resistors.
    I will try to sand thoe covers and see how it will look. If it won't change anything I'm just gonna leave those leds naked. It is soooo beautiful when they nekaed, so delicate, and solid:) I love it - in real it looks 100% better than on photos:)
  7. The boy 4rm oz
    10 Apr 2008
    Personally I think the LEDs look better naked, without the plexi triangles, just my 2cents. I have missed out on a bit, you are making some very good progress, looking better than ever.
  8. phinix
    28 Apr 2006
    Thanks man. Yeah, I think I'm gonnas tay with naked leds, they are pretty as hell:)
  9. phinix
    28 Apr 2006
    ...I wonder why my project has still only 4 stars...:(
    Maybe it sucks..?;)
  10. jhanlon303
    7 Sep 2006
    Some jealous forum member came in and gave it a really low star vote. I gave it 5 ages ago.
    john
  11. ricickle
    ricickle Reamer
    27 Mar 2008
    Naked looks better man
    Glad to see you have got them working
  12. jhanlon303
    7 Sep 2006
    Appears back at 5 stars now where it belongs.
    john
  13. phinix
    28 Apr 2006
    Probably you're right:)
    Thanks again for those leds man:)
    Sweeeet:D
  14. tyrandan
    tyrandan Pink Lemonade.
    2 Mar 2009
    Been following this thread for awhile, good job Phinix, and nice skillz with teh plexi lol.... I hope to see this get finished, I know its gonna look really good.
  15. stuartwood89
    20 Aug 2008
    You're welcome :p
  16. phinix
    28 Apr 2006
    uu.. was it you? thank you very much:)
  17. tyrandan
    2 Mar 2009
    Oh, +1 for naked :rock:
  18. phinix
    28 Apr 2006
    So naked it is..:)
  19. phinix
    28 Apr 2006
    Small update today - I put that chrome tape on bottom panel and mounted two acrylic pieces, SSD mount frame and pump plate.
    What I also did today is I mounted Noctua fans on new Feser radiator, which was also flushed today with de-ionised water. Fan configuration is pull.
    Just for a few minutes I tried the holes for screws and screwed Vertex to its frame. Looks pretty cool! I used small 5mm stand offs between SSD and frame to leave a space for air circulation.
    Take a look on all this stuff...
    Also after a long time waiting for its turn, graphic cards water block has been cleaned (ketchup and lemon juice did the trick:))
  20. .Fatality.
    .Fatality. What's a Dremel?
    10 Jul 2008
    looking good !
