Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    :hehe:
    I like the suspension system you have for the hdd!
  2. Tolk
    Tolk Keep it simple, build it incredible
    7 Feb 2008
    awesome attention to detail..
    love the design and the small touches. :D
    -Tolk
  3. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Thanks... This is my first build so dont want to ruin it...:hehe:
  4. phinix
    28 Apr 2006
    OK, UPDATE TIME !!!!!!
    OK.. I flushed everything... NOW - question is - where to install the fillport - I think it should be between radiator and pump right? where cool water is coming back to the pump.
    Does it matter which hose I'm gonna install in lower radiator hole? It will sit on its side, so I wanted to put out going hose on the bottom hole and then put Tline there for fillport, where from water will go to the pump/cpu-block. Then it will go to GPU and go back to radiator, upper hole.
    ANY SUGGESTIONS???
    blue hose - cooled water coming out from rad to cpu block/pump, green one is for fillport, red one coming out from cpu to gpu and back to rad...
  5. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    normaly.. aren't you using a res. =???
  6. phinix
    28 Apr 2006
    No. I dont want it.. useless...
  7. phinix
    28 Apr 2006
    NOW - I'm running this loop and noticed that pump is really hot. Not even attached to cpu! Should it be hot running on full speed?
    Top of the pump is sooo HOT that I cannot touch it !!!!!
    It sounds like water in pump is boiling...:(
    Radiator is getting warmer too... and I'm not even cooling anything right now!! What is going on? is it pump broken?
  8. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Wouldn't it be better to attach the fillport hose to the hose that is placed the highest? So that the bubbles that go up, will end up in the fillport hose?
  9. Cheapskate
    13 May 2007
    It sounds like you still have a lot of air in the line. I went back through your log and never found a pic of you pump, so I have no clue what kind you have. It seems odd that they would get THAT hot though, even when straining from foamy coolant.
  10. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
    Very interesting project, I want to do something similar myself. Keep it up :thumb:
  11. phinix
    28 Apr 2006
    Yes, I actually did that 30 minutes after drawing that sketch:)
  12. phinix
    28 Apr 2006
    Probably you are right - air is the problem I started to shake a little the whole loop, move around the pump to take away the air from it - noticed that all air which was getting out of the rad went and stoppped in the pump.
    Pump is Swiftech Drive 350 - pump/cpu block.
  13. phinix
    28 Apr 2006
    ok.. so this is all what I got..
    Which clamp should I use for my pump? the left one is what I bought before, right smaller one is original from the package.. I think I'll with bigger, stronger one...
    After a while I managed to put all things together..
    Here're some close-ups of all fittings... clamps not fitted yet...
    Should I put a clamp on fillport as well????
  14. phinix
    28 Apr 2006
    After 1 hour of running it started to be quiet.. very quiet.. practically silent. But still HOT....:(
  15. phinix
    28 Apr 2006
    SO now it is silent, but still HOT.. hard to explain how hot it is.. well... the main plastic logo on the pump is coming off, cause the glue under it is melting...:( THAT hot...
  16. b4i7
    b4i7 modding dreams into reality
    7 Apr 2007
    i had something similar happen to a pump on a cnc laithe i used to run.... up by where the motor is ...its getting burning hot right?
    i cant remember off hand what caused this...ill give my old boss a call and ask him
  17. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    I would contact swiftech as all the reviews i have read about the Drive pump/block it has not gotten hot at all.
  18. phinix
    28 Apr 2006
    yes, burning hot...
  19. Cheapskate
    13 May 2007
    It won't hurt the delrin casing to get that hot, but who knows what it will do to the electrical bits.
    I'm at a loss on the pump, so I'll answer the easier questions.:D
    -The hose clamps supplied with Swiftec gear fits normal vinyl tubing and are too small for tygon.
    -I would put a clamp on the fillport too. A closed loop can produce some serious pressure when it heats up.
  20. phinix
    28 Apr 2006
    Thanks Cheapskate. Yes I put the bigger one on pump:)
    Now the pump is silent but do not know where that hot is coming from...:waah:
