Scratch Build – In Progress ****** PHINIX CUBE ******* - the one and only:)
Discussion in 'Project Logs' started by phinix, 3 Dec 2007.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    What now I'm going to do is to cut rectangle hole for motherboard I/O panel in rear cube panel... everything is already sketched:)
    Some of those LINES are now mine, it was my little daughter, she took over the pen when I went for sth to drink.. it was just about 8 seconds.....:eeek::wallbash:
    As you can see I also drew the hole for PSU... also to be cut...
  2. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    You did a great job on that motherboard tray!
  3. jhanlon303
    7 Sep 2006
    This just keeps getting better:rock: Fine work on the plastic.
    Your weather looks like mine in Colorado - wait an hour and it will change. Love spring.
    John
  4. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
  5. phinix
    28 Apr 2006
    Thank you all guys! It's great to hear that you like my work..
    OK, so I cut out that PSU hole plus mobo I/O panel. Both are rough, need to be sanded and polished now. So leaving you with last 2 pictures of it, going back upstairs to finish this beauty...
    P.S. - weather is so beautiful today.. snow, cool and nice sun - my favourite weather! :) I hate when it's too hot, love the winter/spring period....
  6. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Why do you have only three stars? You deserve more, I'll try ;)
  7. rodeo45
    rodeo45 Who's your daddy ???
    4 Mar 2008
    I always loved cubes, I saw other project like this, based on CUBE the movie. I like your cube, but I think you sent too much time on planning, instead of taking dremel in your hands:)
    I hope we gonna see more improvements soon!?!?!?
  8. phinix
    28 Apr 2006
    Well, you need to understand planning is the most important in modding or building from scratch... it is finally pretty hard work...
    and yes, you will se sth today ...
  9. phinix
    28 Apr 2006
    THE THING !!!
    OK. I think it is time to show you something huge compare to all previous updates.. Something that will take your breath away (well.. took mine :hehe: )
    Something that will show you the whole idea why I wanted to create that cube, pure acrylic cube. Considered by many as the hardest material to mod…
    ARE YOU READY TO SEE IT ??? !!! CAN YOU HANDLE THE TRUTH ??? !!! :eeek:
    WILL YOU BE ABLE TO LIVE AFTER YOU SEE IT??? !!! HAAA ???? WILL YOU ??? !!!!!! :naughty:
    (...ok.. I think I pushed it too far… :eeek: anyway...)
    . . . ARE YOU READY ? ? ? ! ! ! :dremel::dremel::jawdrop::jawdrop:
  10. Guest-23315
    Guest-23315 Guest
    YES already!
  11. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    øhh yes??? and yes you pushed to far .. ! .. dont think its a good idea to wirte that if you want some votes.
  12. phinix
    28 Apr 2006
    ...and now, here it comes. 18 photos of sweet pleasure.... No more words... The one and only...
    PHINIX CUBE !!!
  13. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    is it done ?
  14. phinix
    28 Apr 2006
    OK...
    Some things need to be explained here...
    1 - FYI - When you go back a few pages you will see that I explained why I'm using those rectangle washers - they are NOT permanent - I had to use sth to fill they gap between main panel and head of the bolts - in the future I will add a red decoration panels, didnt want to cut the bolt just to fit them nicely...
    2 - top panel is not screwed yet, will be done later, now I needed it to be easy to take off...
    3 - radiator feet will be cut to shape later on, so they won't stick out from that radaitor back plate...
    4 - front panel is not screwed to the end - I mean again - no washers there so there will be a main front red acrylic panel soon...
    5 - mobo tray is not screwed to the cubic columns, not yet... I needed it to be easly taken out...
    And the last thing - it is not finished yet:)
    I would like to put all the parts inside and enjoy the view but I have to do some more moves. I need to drill holes for bolts for PSU, cut a hole for a fillport, cut holes for graphic card, cut a main hole for radaitor exhaust and create a nice grill for it, prepare front red panel, cut a hole for dvd slot-in, which I need to buy...
    There are things I need to do before I'm gonna run this whole stuff inside my sweet cube:) Don't worry, it's gonna be a lot faster than before, well I work in 4 shifts pattern and today started first day so that means you will see another big move in next 3-4 days...
  15. mcflaco
    mcflaco What's a Dremel?
    29 Feb 2008
    i dont like the thing you did with the radiator cover! it looks less good
  16. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    where is the slots for expansion ?? what do you do when you want for exampel the new 9600gt graphics card ??
  17. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    well he mentioned that it will be changed.........
    Alan
  18. phinix
    28 Apr 2006
    zwinks - read me previous post please...
  19. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
  20. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Looking good so far, you're doing well :dremel: . Great job on shaping the acrylic by hand - I feel your pain!
    Oh, and nice work on the project log - easy to follow and lots of wonderful pics and sketchup renders - just how we like it!
    I look forward to seeing more. :)
