Scratch Build – In Progress *** PHINIX NANO TOWER *** --- MOTY 2011 nomination !!!
Discussion in 'Project Logs' started by phinix, 9 Nov 2009.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Don't worry my man, will add them this weekend:)
  2. phinix
    28 Apr 2006
    Hello there:)
    Quick update, cause I'm running out of time here - still need to reinstall my OS on new SSD.
    On Saturday morning small package arrived from ChilledPC - Tom cut lots of small acrylic pieces for me - most of them will go on outside of the case. I laso ordered some Tensol 12 glue for acrylic - but I will tell about it later...
    I decided to use two switches for internal lights and front panel. I'm using white led switches.
    Here's small pic of work done today:) Measuring, sketching, drilling and a looooooot of filing:)
    They will be attached on right side of the case, bottom part of the rear panel.
    What I also did this weekend (not much I guess, but wanted to show it) is I cut to size round mesh for cover that I'm going to paint and install on rear radiator. Basically I've "stolen" the idea from one fo the fantastic mod cases of Bill from MNPCTECH :D It was easy cause I got this mesh from Bill, so I hope you don't mind taking your idea, Bill! :blush::D
    Here's the radiator that I will be using - EK triple XT:
    ...and here is the mesh cut to size and on the radiator...
    It will be screwed with small M3 black cap head bolts.
    I don't have any idea yet how I'm going to paint this mesh, but I think it will be some kind of hex shape pattern.
    That is it for now, I will add rest of the photos soon. I've been really busy lately, couldn't find a spare time for my little Tower:( I hope I will get some work on it in next couple fo days.
    Plan of finishing this case till end of August is fading away I guess:D
  3. DeadP1xels
    DeadP1xels Music Enthusiast
    30 Nov 2009
  4. Azayles
    Azayles Member
    6 Jan 2008
    Damn you BitTech server, stop being busy and stuffs! :p
    In other news; Awsum work, Phinix!
  5. phinix
    28 Apr 2006
    Thank you guys!:thumb:
    I should receive Tensol 12 glue fro acrylic tomorrow, which I will use to glue those small acrylic pieces. As I showed before, there will be two "combs" on each side of the case, bottom part, and one bigger "comb" on top of the case, that will go aligned with top aluminium panel hole. I shall add sketchups showing that tonight as soon as I get my system running after reinstallation.
    I've been also waiting for quick connectors from AquaTuning - I need them to continue work on internal parts, especially power chamber. I need to measure how deep they will go and then install last part of chamber top panel. I hope they will show up soon...
  6. The boy 4rm oz
    10 Apr 2008
    Hmm, that res is the biggest thing in this build hahaha. I love the mesh idea.
  7. phinix
    28 Apr 2006
    HAHA:) Yes, this radiator is the biggest item in the build:) It is actually the size of the main structure - frame of the NanoTower is 400mm, where radiator is only about 2mm shorter.
  8. phinix
    28 Apr 2006
    Here's how I'm planning to use those acrylic pieces.
    This is the top comb, it will be mounted on long thin piece of acrylic on the rear edge of 10mm top acrylic panel.
    This is the rear view on all combs..
    ..and here is side view, two combs on top and bottom, same other side.
    Those yellow acrylic plates under the combs will be actually black - decided to change them to black tinted acrylic, will make those "ribs" look more "floating":)
  9. The boy 4rm oz
    10 Apr 2008
    The acrylic accents make it look very sinister, I like it :D.
  10. phinix
    28 Apr 2006
    Thanks man! Yep, that was the plan, I want it to look a bit strange, acrylic shapes intrigue a bit:D
    Well, hopefully front panel will make a first "the WOW hit":)
  11. phinix
    28 Apr 2006
    UPDATE TIME! YAY! :D
    OK, again, it is pretty small update. Basically what I did was I measured up and drilled holes for rivets in side panels. It was pretty hard, cause the holes had to be in exact same place on top cover nad main panel, so I spent few extra minutes to make sure holes are all align perfectly... To be honest I hate this kind of job cause there is no second chance, if you screw it up, you need to cut new panel...:eeek:
    But it all went well, I didn't have to re-drill any of the holes so they are all fine:)
    First I marked holes on top cover, then drilled them. After that I aligned covers on side panel and started making marks in the drilled holes...
    Here it is, top covers landed on side panel... pen in my hand.. no breathing.. steady... point.
    This one here is the side panel screw hole, one hole on each panel ended up half uncovered, so I will have to file a nice hole around it, hex shape hole, to match the theme. Rest of the holes are under covers, so I just drilled them through.
    Now, here's the QUESTION!
    I need to attach those covers to side panels with something.
    Which should I go with - black rivet, cap head screw or button head?
    See, really nice holes drilled through both alu panels:D
    I'm really happy that all went well. It was around 200 drills made! Including cleaning with coutersunk drill bit of course:)
    I attached covers with small M3 screws for now to keep them together.
    All holes drilled and cleaned, second panel to be showed later!
    Now, I should do some more work this week, if not, then weekend, so stay tuned!!!:rock:
  12. Azayles
    Azayles Member
    6 Jan 2008
    Looking sharp!!
  13. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This is more than epic! Love that build so much! Mod on mate! ;)
  14. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Button head bolts get my vote, especially in black.
  15. Azayles
    Azayles Member
    6 Jan 2008
    I'm torn between the button and the rivets, tending more toward the rivets 'cause of their flatter profile.
    The screws don't suit the sharp, sleek look of the side panels.
  16. stonedsurd
    11 Mar 2009
    I vote black button heads.
    You're going to have a hard time deciding, phinix! :D
  17. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Great stuff on all accounts. Keep 'em comin'! :dremel:
  18. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    I vote for button heads. Rivets tend to break up randomly. Sometimes a rivet shank gets lodged inside the rivet body and it rattles like a pie in a cupboard.
  19. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Button head screws would look better, or at least in my mind
  20. oliverw92
    oliverw92 New Member
    15 May 2009
    Button head :)
    Can i ask why you got Tensol 12 over Dichloromethane (otherwise known as liquid solvent cement)? I have only ever used Tensol where i need to bond large expanses of acrylic together, however it takes a while to dry. Dichloromethane, on the other hand, bonds within seconds and has a water-like consistency which means you can use capillary action to bond acrylic parts together - it looks like it would be perfect for those small parts.
