Scratch Build – In Progress *** PHINIX NANO TOWER *** --- MOTY 2011 nomination !!!
Discussion in 'Project Logs' started by phinix, 9 Nov 2009.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Too late!
    (Come on - it was just BEGGING for it)
  2. Watchtown
    Watchtown What's a Dremel?
    2 Mar 2010
    There now i tricked the others to think your working faster on your mod, ts really sexy and clean looking<3
  3. voigts
    voigts What's a Dremel?
    26 Apr 2006
    This mod is just incredible.
  4. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Picture quote fail :lol:
    Nice work as always pinix!
  5. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    Hows it going? Are we there yet? I forgot to pee before leaving the house!
    I will give you more +rep while I wait patiently for more of your updates :)
    Loving this mod of yours, inspirational! :rock:
    Hope it's all going ok!
  6. Combatus
    16 Feb 2009
    Exquisite work Mike. This is going to look achingly good!
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Awesome, looking forward to next update... I love that yellow acrylic
  8. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    There is no way that this mod can be more awesome. I think you ve reached the level my friend.
    My deepest and most sincere respect!
  9. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    You've caught the eye of the big dogs. Time for an update! *poke*poke* ;)
  10. Nutman
    21 Oct 2008
    Yeah, we need our shot o' yelloh!
  11. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Dang still no update, curse this good weather!!
  12. phinix
    phinix RIP Waynio...
    28 Apr 2006
    "We gonna rock down to Electric Avenue And then we'll take it higher!!!"
    Hi guys! Happy Easter! :D
    Thank you all for comments - and waiting! :D
    I've been busy in last couple of weeks, again...
    Did some work on my little Tower so it was time for an update.
    I have installed slim dvd in the front, using thin aluminium strips and some velcro pads. As you can see those mounting I made are suppressed on rubber washers, so vibrations from dvd drive won't go on Tower.
    Also after a week of painting all parts, I put together pump stand. I left few bits unpainted to make a nice contrast.
    Also braided led cables in side panels and attached 2-pin connector for easy disconnect.
    After that move I was able to install front and left side panel.
    Here's how the Tower looks right now:) All braided wires waiting for connection junction.
    Also braided wires on that reservoir ring cover, added 2-pin connector for thermometer that will be plugged with Bitspower plug, also braided on photo.
    Another thing I did was I finished right side panel, added "led modules":D
    Look what mess I made on my desk!!!
    After that it was time to finally finish front panel. Before i attached leds to the back of it, I had to glue all 14 hex shapes on the front.
    First I had to drill 12mm holes in each of those acrylic hex shapes.
    Then I had to paint all aluminium hex shapes.
    I used matches to stick them with masking tape.
    Put them all up and spray painted, satin black.
    Hex army...:)
    Then I glued them all together with acrylic shapes.
    Here is front panel and glued hex shapes. I decided to glue them to main panel using double side tape.
    ...and finished front panel. ALL DONE! FINALLY! :D
    I like the look of it in the sunlight. Pretty:blush:
    Then I spent 100s of hours on soldering leds behind it. I pushed in one led in each of those holes through the panel and to the acrylic hex shape, where each head of leds were angled 90 degrees to light up acrylic edge. Lot of work, but it was worth it.
    I tried it and plugged front panel to PSU... It was breathtaking....
    Unfortunately you guys going to see this on the final update and final presentation of the Tower.
    Soon.. pretty soon:) About 3 weeks from now:)
    Samaya likes this.
  13. bulldogjeff
    2 Mar 2010
    Thats just to much niceness. Looks superb . Has to be a MOTY contender once it's finished. Top modding dude:D:thumb:
  14. alain-s
    alain-s Minimodder
    12 Jan 2011
    Very nice build Phinix
    Everything fits so nicely together cant wait when u will finish it.
  15. Cheapskate
    13 May 2007
    Almost there.:rock:
  16. IcyAero
    IcyAero What's a Dremel?
    4 Aug 2010
    I love the size of that superb build, been planning a similar build - nowhere as awesome as yours though! :blush: :rock:
  17. KidMod-Southpaw
    28 Sep 2010
    Beautiful. It's your attention to detail that makes this so wonderful to look at! This mod has never failed to impress me throughout. Well done phinx.
  18. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    sweet update !
  19. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Just stunning Phinx been popping by now and again since the start but I think I missed the update where you created the clear plexi base! awesome addition!
  20. Samaya
    Samaya Lion Country
    2 Jan 2008
    WOW!!! I like your build. Attention to detail is fantastic. Can't wait to see the final pictures.
