Phobya water-cooled case design thread - Stage 1 - Complete - see Stage 2 thread
Discussion in 'Watercooling' started by Combatus, 1 Nov 2010.
Thread Status:
Not open for further replies.
  1. Dima_V_Ukraina
    Dima_V_Ukraina What's a Dremel?
    23 Nov 2010
    Good evening. I write on Russian, English know badly. Corps of standard form. From one side all komponenty of computer, de autre part radiators of the cooling system. the radiators of 200*200mm blow them 3 ventilators of 220mm,ventilyatory are regulated and turned off, a tank is home-made on 2 l. A pump works on 5v. The system works demon of ventilators, stably
    Cpu fenom 965
    Video radion 5770 *2 cros fire
    2*2 1600 ram
    2*500 gb raid 0
    Dvd notebook slot
    Video http://smotri.com/video/view/?id=u17895337eaf
    Blog http://www.dpk.com.ua/blog/23621.html
    Foto http://xmages.net/show.php/2043922_img-3715-jpg.html
  2. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    I see. good design. How do you export it as 3ds?
  3. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    I have SKU 8 Pro. I don't think the free version allows for .3ds exports, but if it does it would be under File->Export->3d Model
    And then you would choose the .3ds file type from the drop down on the next window...
  4. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Small update, I have't had a lot of time to work on this but here are a few small changes.
    -Rotated motherboard to "traditional" orientation
    -Added front loading slim drive
    -Added top 2x 120/140 fan grill and holes for external rad mounting.
    -Small aesthetic tweaks
    Overall Dimensions: 560x576x236
    I am now working with SolidWorks 2011 so the renderings aren't up to par. I am still playing around with it but hopefully Ill get an animation up sometime soon.
  5. Sergey.Akinshin
    Sergey.Akinshin What's a Dremel?
    24 Nov 2010
    Hello!
    recently learned from the site modding.ru that there is such a wonderful contest
    give the photo of his body
    to alter its course under water cooling I'm not going to prepare a draft but not a problem
    in principle, change only the top box, it will be more to install a radiator and pump
    slightly changed dimensions
    to estimate its size
  6. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    Looking good guys make sure you get your e-mails in to complete stage 1!
  7. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    just waiting on the rest of the pictures that show off the features of my case design, but for now, a preview
  8. Razer2007
    18 Jul 2010
    pfff ok how much is the pro version?
    No No No, your design just keeps getting better! this looks so cool!
  9. xXSebaSXx
    21 Aug 2010
    SKU Pro = $495 US. I got it as a bday present a couple months ago... Otherwise I'd be using the free version just like most people.
    Made some changes... Changed the 5.25 Bays... broght it down to 4 bays (more than enough) and modified the cage to hold just the 4 and fit in between the two dividers...
    Added the side panel that goes behind the MoBo and added to windows (top and bottom with hex mesh) for air intakes or exhausts depending on radiator orientation.
    Added some openings on the front side of the case for air intake... still not 100% convinced on those, so I'm open to suggestions.
    A couple of "Clay" renders...
    Again... Suggestions and critiques are welcome and appreciated.
    Sebastian
  10. Razer2007
    18 Jul 2010
    It's a nice design. Well laid out. I really like the big cpu backplate cutout, and the cable management holes
  11. xXSebaSXx
    21 Aug 2010
    I'm glad you like it my man... You have shown us that you have quite a high level of talent and taste when it comes to case design, so your opinion is valuable to me.
    PS:
    I took my case design to the paint booth and ran a color test on it... I have to say; I'm really liking this color combination.... It really pop out at the eye!
  12. Razer2007
    18 Jul 2010
    Thanks man!
    I also like the color. A lot like some of the lian li cases. I must say, theres a lot of room underneath the mobo tray!
  13. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    here is my design no chance to win though with the designs already here
  14. rayson
    23 Jul 2010
    why does it come small
    No worries, fixed it. Thanks for the tip, subtec! --Nexxo
  15. aquatuning
    5 Jul 2006
    are you getting the link from the thumbnail and not the main picture?
  16. subtec
    subtec drawing boxes
    4 Nov 2010
    Take the ".th" out of the image URLs
    Like the first one is
    Code:
    http://img163.imageshack.us/img163/3584/xzcvgsdfgvs.th.jpg
    change it to
    Code:
    http://img163.imageshack.us/img163/3584/xzcvgsdfgvs.jpg
    and make sure they're surrounded by the IMG tags
  17. Zesti
    Zesti Aluminium + file
    9 Feb 2010
    My final update for stage 1.. Haven´t changed much since last update because studies and other projects have taken so very much time. I just did some minor things like taking 9 mm out of height etc. Hopefully I can continue adding details and trying a couple new things in stage 2.. :worried:
    Main specs:
    Case dimensions:
    -500 mm (H) x 220 mm (W) x 600 mm (D)
    -19.69"(H) x 8.66"(W) x 23.62"(D)
    Supports Mini-ITX, microATX and ATX motherboards
    Materials:
    -1.5mm and 3mm aluminum
    Cooling:
    -Two chamber design
    -Bottom chamber supports up to 4x120mm radiator and second 2x120mm radiator (for dual loop)
    -Upper chamber: 2x 120mm intake fans (positive air pressure), cooled HDD gage
    11 drive bays:
    -3 x 5.25"
    -5 x 3.5" for HDD
    -3 x 2.5" for SSD
    Others:
    -CPU and cable cut-outs
    -Removable motherboard tray, HDD-gage, midplate and PSU mounting plate
    -Possible to configure to ATX or inverted ATX
    And pictures:
  18. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Great work guys..
    Aww crap 2 days to go.. When I drop my kids off to their mum tonight I'm cracking open a brew and getting the design done!
  19. Sergey.Akinshin
    24 Nov 2010
    Here's an example project
  20. Razer2007
    18 Jul 2010
    yeeah you better! but don't rush. remember it's only rough concepts for stage 1.
Thread Status:
