photo editing
Discussion in 'Photography, Art & Design' started by wizzy2k5, 9 Jul 2007.
  1. wizzy2k5
    wizzy2k5 what???
    4 Jul 2007
    I have a photo editor and am trying to get some use out of it :D so I tried a sunset shot , can someone please tell me where I went wrong or if its ok what can I do to make it better
    Here are all 3 photos
    which one is the best and what could I do more to improve it?
  2. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    In Adobe Photoshop CS3 I've only did "Auto Levels," "Auto Color," and "Auto Contrast"
  3. wizzy2k5
    wizzy2k5 what???
    4 Jul 2007
    nice :D what could you do for a sunset scene? as thats what I want to try and get use to for a starting point
  4. OleJ
    OleJ Me!
    1 Jul 2007
    For a sunset effect I'd suggest you keep the first pic as the lower layer, then have the 3rd on top and add a mask with a gradient to the 3rd (top layer) Having the gradientmask reveal the red in top of the pic and yellow below. But do make it a large shift.
  5. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    Difficult subject, so not easy to get right. First make sure the white balance on the camera is set to "Daylight" otherwise it will try and move the colours towards an average grey. That way you capture the yellow or red colours in the light. If your photo editor allows, change the white balance / colour balance
    Secondly there seems to be some flare which makes the image flat - you can compensate for some of this by increasing contrast in your photo editor. There is some good detail in the image, so do some sharpening and then increase saturation selectively for the different colours in the image.
  6. wizzy2k5
    wizzy2k5 what???
    4 Jul 2007
