Other Photo Recovery on Android
Discussion in 'Software' started by lilgoth89, 21 Feb 2016.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    so my mother turned to be earlier on after accidentally deleting some of her old photos on her Galaxy S5 Mini and asked if i could recover them
    so i fired up Recuva from Priform and set to work as normal, only to be stopped instantly by Recuva, not being able to communicate with my mothers phone, so i went to manually set it to mass storage mode only to find the option has now been removed. The only options are PTP or MTP
    so basically i need a program that can recover her photos from the device either installed to the device or used from my PC
    any thoughts ?
  2. roundyz
    roundyz What's a Dremel?
    16 Jan 2002
    could you flash it to a rom that supports mass storage mode and leave the user partition (SD) intact?
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Worth checking to see if they've automatically been backed up to google drive? (it's usually on by default)
  4. wolfticket
    19 Apr 2008
    I generally wouldn't advise writing to storage you wish to recover from, but a quick search of the Play Store suggests there are a few well reviewed recovery apps for Android that would run on the device.
    I think my go to recovery software PhotoRec might be able to do MTP too: http://www.cgsecurity.org/wiki/PhotoRec_FAQ
  5. Rhydian
    Rhydian What's a Dremel?
    13 Nov 2010
    Could be backed up on a few options on the phone she doesn't know about.
    Dropbox and Drive etc.
  6. Duncan7722
    Duncan7722 What's a Dremel?
    26 Apr 2016
    I also need to recover my deleted photos from my Samsung S6, any help?
  7. afrasiab
    afrasiab What's a Dremel?
    13 Feb 2017
    the photos can be recovered easily by using apps which are available on playstore. I have used an app which I find on playstore which have recovered my photos.
