Other Photos of your computer
Discussion in 'Hardware' started by [KNIGHT], 9 Jan 2010.
  1. Parge
    16 Jul 2010
    Well, if you can call drilling out 6 rivets modding then....well that.
    Just to remove the lower drive cage. Takes 5 seconds.
    Then you get some XSPC 80-120mm adaptor mounts from Specialtech (or for free from me, as I have some spare - thanks to 23RO_UK) and attach them to the 140mm fans at the front of the case to hold the Rad in place. Not easy to see but I'm also using two zip ties to hold it in place.
    The XTX is 60mm thick and there is ample space in the front there as you can see.
    JJ! Yes indeed! They are truly excellent radiators. Keeping my SLI'd 480 GTXs under 65C with Furkmark and Prime 95 running!
  2. Guest-56605
    Guest-56605 Guest
    Very very nice job mate :thumb: :D
    Nice to see a concept in working practice also, told ya it would do the job ;)
  3. Sarakon
    Sarakon The German
    11 Feb 2011
    Not very clean. For some reason I took the pictures before cleaning out the dust:
  4. KidMod-Southpaw
    28 Sep 2010
    I think your cables could do with a bit of sorting at the back. :)
    And that big 20mm fan strapped to the drive bays is a bit of an eyesore too. :p
  5. Sarakon
    Sarakon The German
    11 Feb 2011
    I know. So much effort :p The big fan you do not see once the side panel is on. The corsair fans are a bit loud, so I need that fan otherwise my graphics card gets a bit warm in summer, I don't need it for the winter though. Once I get my SSD I will have a BIG cleanup.
  6. Tangster
    23 May 2009
    I figure I'll post up my re-cable tidy after installing a shiny new SSD. Might not be obvious but there's an extra 120cm of cable extensions there. :) Decent job, methinks.
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
  8. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    Needs a bit of cable management when I can find the time!
  9. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
  10. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Why these h000ge cases with mATX in them?
  11. Somer_Himpson
    22 Jan 2010
    Love ROG mATX boards...no specific reason.
    Also, with 9 case fans, it has a lot of room to breathe!
  12. Bloody_Pete
    11 Aug 2008
    I think he was talking about mine :p
  13. Sheiken
    Sheiken Wat?
    9 Jan 2005
    To be honest, I was talking about both of you guys ;)
    Probably just me, but it seems like a waste of space?
  14. Sheiken
    Sheiken Wat?
    9 Jan 2005
    This is a proper mAtx setup ;)
  15. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I love the way that in that Silverstone Case; everyone winds up just mouting the SSD's by bolting them down with double-sided tape or sticking them behind the rear-panel or something.
  16. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Well there is actually 2.5" mounting holes on the floor of the case. But I'm not sure if you are serious or not :p
  17. .//TuNdRa
    12 Feb 2011
    Both. I've wound up mounting an SSD using a couple of squares of double-sided sticky foam. (It was an old ThermalTake Xasar, I figured that it wouldn't be shifted much, so the foam would do), but I often see SSD's just lying against back-panels and such, held in place by nothing but friction and prayer.
    That said; Mine is mounted, mounted stupidly, but mounted. Silverstone didn't think their SSD bracket all the way through. it's the wrong way up, so the lip of the drive-cage means a normal power cable can't reach it. I've had to mangle a spare molex - sata extention cable to get power to it. It only works because the cables are thinner than i'd like, anything thicker and it'd warp the connector on the SSD itself.
  18. Tangster
    23 May 2009
    I had the same problem, if the SSD mount was made so it had the SSD connectors facing down I wouldn't have had to use an annoying little molex to sata connector.
  19. .//TuNdRa
    12 Feb 2011
    Yup. It's good for keeping the good-looking side of the SSD facing up, but it's a pain in the ass to make a connection to.
  20. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I must admit, I am contemplating just hiding it out of sight behind the motherboard with some velcro.
