Development PHP Color Chart :D:D
Discussion in 'Software' started by Bogomip, 17 Feb 2003.
  1. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
  2. sheepgoat
    sheepgoat What's a Dremel?
    8 Nov 2001
    i love little scripts like that.
  3. Mr. Roboto
    Mr. Roboto xBurningMikex
    3 Dec 2002
    there are many possible hex colors.
    16^6
    16 to the 6th power would tell you all possible.
  4. sheepgoat
    8 Nov 2001
    16,777,216 possible hex colors to be exact
  5. Bogomip
    15 Jun 2002
    hold on hold on... you mean you could have...
    #cd18ba
    and internet exporer would make it up ? it doesnt have to be
    #bbaacc
    i.e. 2 of the same, 2 of the same, 2 of the same ?? I didnt think They worked that way!
  6. complexprocess
    complexprocess What's a Dremel?
    8 Jul 2002
    Yeah, it can be 6 different characters. Each number of each pair controls either "hue" or "tint" as I recall (I think that's the order, as well, but don't quote me.) However, you would be hard pressed to tell the difference between #996633 and #986633 or any other very similar combos. Once you get in to differences of 5 or so (#996633 versus #9433) you can start to notice it at a glance, but even then the difference really is too small to be practical.
    As an example, paste this code into a file and slowly change the color of the second cell by one unit in the second part of a pair (in #986633 you might try lowering the 8) until you can really see the line between the two without staring to hard. Read that again and it will make sense. :D
    Here's the code:
    PHP:
    <table border="0" cellspacing="0">
    tr>
    td width="100" bgcolor="#996633">
    nbsp;
    td>
    td width="100" bgcolor="#986633">
    nbsp;
    td>
    tr>
    table>
    P.S. please forgive my choice of colors. I typed them in before I thought about what they would look like and was too lazy to change them.
  7. Bogomip
    15 Jun 2002
    i dont care about how small the change is :) i want all the colors ever :D the coding is simple, the browser tryign to recreate it all, is less simple :)
  8. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
  9. djengiz
    djengiz Pointless.
    16 Aug 2002
    pwitty!
