Development PHP development GUI's?
Discussion in 'Software' started by Zoon, 27 Oct 2009.
  1. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I'm currently using notepad++ to develop some website stuff on and off, but I was wondering if there were any decent, free, windows based ones around, which help with code generation and templating etc, such like Visual Studio does with c#/asp.net - has anyone used any and can you recommend me some? Thanks.
  2. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Eclipse can do PHP. It's typically what I use. That's mainly coz I'm used to it for my Java development though.
  3. FuzzyOne
    FuzzyOne
    19 Sep 2002
  4. dfhaii
    dfhaii internets
    24 Mar 2002
    A long time ago when I used to write PHP, Zend studio was my IDE of choice, if I recall correctly it wasn't too pricy, or you could get free trial versions...
  5. Zoon
    12 Mar 2001
    Thanks very much for the feedback guys.
    I've elected to use CakePHP for the rapid development environment, and Notepad++ seems to be good enough for that :)
  6. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Dreamweaver or NetBeans PHP or Notepad++ for me
