Development PHP: extract set of numbers from a string
Discussion in 'Software' started by ajack, 22 Nov 2007.
  1. ajack
    ajack rox
    17 Apr 2003
    OK so basically I have a string which represents a date but the formatting is non-uniform (i.e. it could be '2000', '12th January 1999', '01-01-2000', etc. (The year will always be a 4 digit number though)) So I need to extract just the year from this string in PHP. Clearly a regex is needed but tbh I've only ever used them very briefly in the past so a nudge in the right direction would be appreciated :)
  2. mutznutz
    mutznutz Cos Ive got a beard u label me evil
    18 Nov 2007
    You could do this
    $test = explode("-",$string_u_want_to_get);
    $year = $test[2];
  3. Zut
    Zut What's a Dremel?
    5 Feb 2005
    Use 'strtotime' to parse the number in whatever format, to turn it into an integer timestamp. Then you can use 'date' to extract the token you need. e.g.
    PHP:
    $fuzzyDate "12th Jan 1999"
    $timestamp strtotime($fuzzyDate);
    $year date("Y"$timestamp);         // Will be "1999"
    $month date("m"$timestamp);        // ..."01"
    $dayOfWeek date("l"$timestamp);    // ..."Tuesday"
    Have fun!
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    PHP:
    $str_date "12th August 2007";
    $matches = array();
    if (
    preg_match('/(\d{4})/'$str_date$matches)) {
    $year $matches[1];
    print_r((int)$year);
  5. ajack
    ajack rox
    17 Apr 2003
    Wicked, last 2 work great, thanks dudes :)
    mutznuts, that would only work if the date was 'xx-xx-xxxx' which (as in my first post), that is not always going to be the case.
  6. mutznutz
    18 Nov 2007
    Apologies, didn't read it quite right :)
