Development PHP Hit Counter Problems
Discussion in 'Software' started by Dinh, 11 Jun 2006.
  1. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    I am having a problem with a friend's hit counter script, which was modified a few times from the original. He basicly wants the "Today's Unique Hits" and "Total Uniques" only to be visible, which is accomplished. But the counter itself is stuck at 1, no matter what. I've tried changing permissions on stats.txt, but it simply does not work because it does not log the ip? Any help would greatly be appreciated.
    How the log file supposed to look like(x's are there for a reason):
    Code:
    7x.247.231.220|30June2005
    How it looks like now:
    Code:
    |11June2006
    |11June2006
    |11June2006
    |11June2006
    Code:
    <?php
    // Our log file;
    $counter = "stats.txt";
    // Date logging;
    $today = getdate();
    $month = $today[month];
    $mday = $today[mday];
    $year = $today[year];
    $current_date = $mday . $month . $year;
    // Log visit;
    $fp = fopen($counter, "a");
    $line = $REMOTE_ADDR . "|" . $mday . $month . $year . "\n";
    $size = strlen($line);
    fputs($fp, $line, $size);
    fclose($fp);
    // Read log file into array;
    $contents = file($counter);
    // Total hits;
    $total_hits = sizeof($contents);
    // Total hosts;
    $total_hosts = array();
    for ($i=0;$i<sizeof($contents);$i++) {
    	$entry = explode("|", $contents[$i]);
    	array_push($total_hosts, $entry[0]);
    $total_hosts_size = sizeof(array_unique($total_hosts));
    // Daily hits;
    $daily_hits = array();
    	if ($current_date == chop($entry[1])) {
    		array_push($daily_hits, $entry[0]);
    $daily_hits_size = sizeof($daily_hits);
    // Daily hosts;
    $daily_hosts = array();
    		array_push($daily_hosts, $entry[0]);
    $daily_hosts_size = sizeof(array_unique($daily_hosts));
    <? echo "
    <strong>Unique hits:</strong>  " . $total_hosts_size . "<br>&nbsp;
    <strong>Todays unique hits:</strong> " . $daily_hosts_size;
  2. dfhaii
    dfhaii internets
    24 Mar 2002
    It's not logging the IP because $REMOTE_ADDR is empty, you want to replace it with $_SERVER['REMOTE_ADDR']
    Col
  3. FuzzyOne
    FuzzyOne
    19 Sep 2002
    Which will return there proxy ip if there using a transparent one.
    Use this instead
    PHP:
    function getIP() {
        if (isset(
    $_SERVER)) {
            if (isset(
    $_SERVER['HTTP_X_FORWARDED_FOR'])) {
                return
    $_SERVER['HTTP_X_FORWARDED_FOR'];
            } else {
                return
    $_SERVER['REMOTE_ADDR'];
        } else {
            if (isset(
    $GLOBALS['HTTP_SERVER_VARS']['HTTP_X_FORWARDER_FOR'])) {
                return
    $GLOBALS['HTTP_SERVER_VARS']['HTTP_X_FORWARDED_FOR'];
            } else {
                return
    $GLOBALS['HTTP_SERVER_VARS']['REMOTE_ADDR'];
