Open Source PHP Multi Query issue
Discussion in 'Software' started by deathtaker27, 12 Mar 2013.
  1. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Hi,
    I have an issue with a multi Query where the error i get is:
    Parse error: syntax error, unexpected 'Cant' (T_STRING) in C:\xampp\htdocs\cars\BuyCar2.php on line 45
    Been looking and I cannot work out what is wrong, code:
    PHP:
    <?php
    session_start
    $sessionstarted 1;
    if(isset(
    $_SESSION['userid']))
    // Allow car to be bought
            // Get Variables
    $carIndex $_POST['carIndex'];
    $UserID $_SESSION['userid'];
    $title$_POST['title'];
    $firstName$_POST['firstName'];
    $lastName$_POST['lastName'];
    $contacthome$_POST['contacthome']; //int
    $contactmobile$_POST['contactmobile']; //int
    $addressLine1$_POST['addressLine1'];
    $addressLine2$_POST['addressLine2'];
    $addressCounty$_POST['addressCounty'];
    $addressPostCode$_POST['addressPostCode'];
    $ccNumber $_POST['ccnumber'];
    $ccSecurity $_POST['ccsecurity'];
    //Connect to server
    $odbc mysql_connect('localhost''root''') or die ("Can't connect to server");
    //Connect to database
    mysql_select_db('cars'$odbc) or die ("Can't connect to database");
    // text: '" blah variable "'
        // numerical: ' boo im a variable '
    $sql "INSERT INTO purchase VALUES (DEFAULT,
    .$carIndex.",
    .$UserID.",
    .$title."',
    .$firstName."',
    .$lastName."',
    .$contacthome.",
    .$contactmobile.",
    .$addressLine1."',
    .$addressLine2."',
    .$addressCounty."',
    .$addressPostCode."',
    .$ccNumber.",
    .$ccSecurity.");
    $result = mysql_query($sql$odbc) or die ("Cant run query");
        if(
    $result)
            //Connect to server
    $odbc3 = mysql_connect('localhost', 'root', '') or die ("Can't connect to server");
            mysql_select_db('
    cars', $odbc3) or die ("Can't connect to database");
            // text: '"
    blah variable "'
    $sql3 = "UPDATE `cars`.`carsSET sold "1"WHERE carIndex ".$carIndex." ";
    $result3 = mysql_query($sql$odbc) or die ("Can't run query");
            if($result3)
                //Connect to server
                $odbc4 = mysql_connect('
                mysql_select_db('cars',
                // numerical: '
    boo im a variable '
                $sql4 = "Select * From cars WHERE carIndex = ".$carIndex." ";
                $result4 = mysql_query($sql, $odbc) or die ("Can'
    t run query");
                // Check data is returned (There are results, not empty)
                if(mysql_num_rows(
    $result4) == 0)
                //Count rows returned, of 0 (no data) do the following:
                        //Echo puts text on screen
                        echo "
    <h4No records were returnedsearch again </h4>";
                else
    $count = 0; // to count number of records returned
                    //Display data that is returned, choose formatting
                    while(
    $row=mysql_fetch_object($result4))
                    // gets one row from the returned query data at a time then displays it
                        <!DOCTYPE html>
                        <html>
                        <head>
                        <title>Purchase Car</title>
                        <link href="
    CSS/default.css" rel="stylesheet" type="text/css">
                        <style type="
    text/css">
                        </style>
                        </head>
                        <body>
                            <div id="
    container"> <!-- Start of container Div -->
                                <?php include 'Templates/AdminHeader.php' ?>
                                <div id="
    maincontent"><!-- Start of Main Content Div-->
                                 &nbsp;
                                    <div id="
    admintext">
                                    <h3>
                                    <?php echo "
    Car Purchased"; ?>
                                    </h3>
                                    <p>You will need to bring the following information with you:</p>
                                    <p>Driving license</p>
                                    <p>Print out of this page</p>
                                    <p>Insurance, we recomend one of these: <a href="
    www.confused.com/car-insurance">Confused.com</a> or <a href="www.moneysupermarket.com/car-insurance/">Money Supermarket</a> or <a href="www.directline.com/">Direct Line</a></p>
                                    <br>
                                    <h3>Additional information about the car:</h3>
                                    <p>VIN: <?php echo
    $carIndex;?></p>
                                    <p>Dealer: <?php echo
    $row->dealer;</p>
                                    <p>Town: <?php echo
    $row->town;</p>
                                    <p>Region: <?php echo
    $row->region;</p>
                                    <p>Telephone: <?php echo
    $row->telephone;</p>
                                    </div>
                                </div><!-- End of Main Content Div-->
                                <?php include 'Templates/Footer.php' ?>
                            </div> <!-- End of container Div -->
                        </body>
                        </html>
                    <?php
        else
            <!DOCTYPE html>
            <html>
            <head>
            <title>Login Required</title>
        <!--    <META HTTP-EQUIV=REFRESH CONTENT="
    5URL=http://localhost/cars/login.php"> -->
    <link href="CSS/default.css" rel="stylesheet" type="text/css">
    style type="text/css">
    style>
    head>
    body>
    div id="container"> <!-- Start of container Div -->
    div id="header"> <!-- Start of Header Div-->
    div id="logo"><!-- Start of Logo Div-->
    img alt="Logo" src="Images/logo.png">
    div><!-- End of Logo Div-->
    div id="companyname"><!-- Start of company name Div-->
    h1 id="companynametext">voiture</h1>
    div>    <!-- End of company name Div-->
    div id="socialmedia"> <!-- start of social media Div-->
    div id="socialmediatext"> <!-- start of social media text Div-->
    p>Follow us on:</p>
    div> <!-- End of social media text Div-->
    div id="socialmediaimages"><!-- start of social media images Div-->
    a href="http://www.facebook.com" ><img alt="facebook" src="Images/facebook.png" HEIGHT="20" WIDTH="20"></a>
    a href="http://www.linkedin.com" ><img alt="linked in" src="Images/linkedin.png" HEIGHT="20" WIDTH="20"></a>
    a href="http://www.twitter.com" ><img alt="twitter" src="Images/twitter.png" HEIGHT="20" WIDTH="20"></a>
    div><!-- end of social media images Div-->
    div> <!-- End of social media Div-->
    div> <!-- End of Header Div-->
    div id="navigation"> <!-- start of navigation Div-->
    ul id="navul">
    Navigation Table -->
    li class="navli"><class="mainnav" href="Index.php">Home</a></li>
    li class="navli"><class="mainnav" href="Login.php">Login</a></li>
    ul>
    div> <!-- End of navigation Div-->
    div id="maincontent"><!-- Start of Main Content Div-->
    nbsp;
    div id="admintext">
    h3>
    Login Required
    </h3>
    p>You are required to login before being able to purchase this car</p>
    p>You will be automatically forwarded to the Login page</p>
    p>If your browser does not support this please <a href="Login.php"click here </a></p>
    p>Once logged in please browse back to the car and click buy again</p>
    div>
    div id="footer"><!-- Start of footer Div-->
    table id="footertable">
    tr>
    td><pCopyright Jason Field |</p></td>
    td><p> <a href="tandcs.php">Terms and Conditions</a> | </p></td>
    td><p> <a href="Contact.php">Contact Us</a> | </p></td>
    td><p> <a href="about.php">About us</a> | </p></td>
    tr>
    table>
    div> <!-- End of footer Div-->
    body>
    html>
    php
    And DefaultHeader incase you are curious:
    PHP:
    <?php
    if(isset($sessionstarted))
    // work around for buy car due to session start being called before this
    else
    Session_start();
    if(isset(
    $userid $_SESSION['userid'];
    // MYSQL_Connect is a function to run odbc for mysql
    $odbc2 mysql_connect ('localhost''root''') or die ("Could not contact server, please contact administrator, Is Xampp running?");
    // Server, User, Password
        //Connect to Database
    mysql_select_db('cars',$odbc2) or die ("Database not found");
    //Database name, Mysql_Connect variable
        // Define SQL Statement to retrieve all records
    $sql2 "SELECT * FROM member Where UserID = '".$userid."'";
    // Retrieve result from SQL Statement
    $result2 mysql_query($sql2$odbc2) or die ("Cannot run query, learn to spell douchebag!");
    if(mysql_num_rows($result2) == 0)
        else
    while($row2=mysql_fetch_object($result2))
                    <html>
                    <head>
                    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
                    </head>
                    <body>
                            <div id="header"> <!-- Start of Header Div-->
                                <div id="logo"><!-- Start of Logo Div-->
                                    <img alt="Logo" src="Images/logo.png">
                                </div><!-- End of Logo Div-->
                                <div id="companyname"><!-- Start of company name Div-->
                                    <h1 id="companynametext">voiture</h1>
                                </div>    <!-- End of company name Div-->
                                <div id="socialmedia"> <!-- start of social media Div-->
                                    <div id="socialmediatext"> <!-- start of social media text Div-->
                                        <p>Follow us on:</p>
                                    </div> <!-- End of social media text Div-->
                                    <div id="socialmediaimages"><!-- start of social media images Div-->
                                        <a href="http://www.facebook.com" ><img alt="facebook" src="Images/facebook.png" HEIGHT="20" WIDTH="20"></a>
                                        <a href="http://www.linkedin.com" ><img alt="linked in" src="Images/linkedin.png" HEIGHT="20" WIDTH="20"></a>
                                        <a href="http://www.twitter.com" ><img alt="twitter" src="Images/twitter.png" HEIGHT="20" WIDTH="20"></a>
                                    </div><!-- end of social media images Div-->
                                    <div id="LoginWelcome">
                                    <h6 id="loginwelcometext">Welcome <?php echo $row2->firstName;?></h6>
                                    </div>
                                </div> <!-- End of social media Div-->
                            </div> <!-- End of Header Div-->
                            <div id="navigation"> <!-- start of navigation Div-->
                                <ul id="navul">
                                <!-- Navigation Table -->
                                <li class="navli"><a class="mainnav" href="Index.php">Home</a></li>
                                <li class="navli"><a class="mainnav" href="SearchHome.php">Search</a></li>
                                <li class="navli"><a class="mainnav" href="Gallery">Gallery</a></li>
                                <li class="navli"><a class="mainnav" href="Logout.php">Log Out</a></li>
                                </ul>
                            </div> <!-- End of navigation Div-->
                    </body>
                    </html>
                    <?php
    else
        <html>
        <head>
        </head>
        <body>
                    <ul id="navul">
                    <li class="navli"><a class="mainnav" href="Login.php">Login</a></li>
                    </ul>
        </body>
        </html>
    <?php
    Thank you for your help in advanced
    All variables are posted from the previous page or grabbed from sessions
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Sorry my mistake, missed a bracket off the end of the first SQL statement :(
  3. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    I was going to point that out...
    your issue is here:
    Code:
     ".$ccSecurity.");
        $result = mysql_query($sql, $odbc) or die ("Cant run query");
    should be
    Code:
     ".$ccSecurity.")";
    you made that mistake twice from what I can see quickly now.
    Syntax highlighting Eff Tee Double-You
  4. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    Please tell me that you are escaping the user input before passing it to that query
  5. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    No I'm not as it is for an assignment which doesn't specify that and with everything else extra I have included I haven't had time to do it.
  6. lp rob1
    lp rob1 Modder
    14 Jun 2010
    This is one of those times in which colour syntax highlighting is really useful.
  7. notmeagain
    29 Jan 2009
    Are you using any specific IDE's for this?
    I'd recommend NetBeans (PHP edition).
    Has full blown syntax highlighting, code completion and syntax checking built in.
